What should be replaced this winter?, cables/fuel lines/etc?? |
Cevan |
Oct 26 2007, 10:31 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I've got a great running '75 1.8. (IMG:style_emoticons/default/driving.gif) When I take it off the road this winter, I plan to pull the motor/trans out in order to clean up the engine bay, deal with some surface rust (I hope it's only on the surface) around the engine shelf, replace the stainless steel brakelines with OEM ones and to do maintenance to the motor (valve adjust, push tube seals, etc).
While I have the motor out, I'm wondering if I should do any of the following: 1. replace fuel lines by the gas tank, in the tunnel and in the engine bay (CFR lines) 2. replace accel and clutch cables I plan to pull the gas tank and inspect all these areas, but given the car is 32 years old and that I've only owned it for about 3 months, is it wise just to place these things now regardless of their condition? Is there anything else I should be doing? |
type47 |
Oct 26 2007, 11:33 AM
the metal fuel lines in the tunnel is a great idea. with the cars being 30+ yrs old, the plastic lines are becoming suspect. however that said, this is what i did and why, not a suggestion and i will probably get (IMG:style_emoticons/default/chair.gif) .
on my 74, the fuel pump is in the stock location. never had any vapor lock problems (insert knock on wood smilie here). since the fuel pump in this location "sucks" the fuel from the tank, the plastic lines are not under great pressure. if the pump were in the 75-76 location or had been relocated, the plastic lines would be under great pressure (~30 psi) and i would not trust the old plastic lines. i did not know about the situation when i had my motor out, if i had, i would have replaced w/metal fuel lines. |
toon1 |
Oct 26 2007, 12:18 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
do it all
Lo-Fi Version | Time is now: 7th June 2024 - 05:55 PM |
