Relay Board, How do I get rid of it? |
chris914 |
Oct 28 2007, 12:18 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I have carburetors, no heater, and an aftermarket fuel pump on its own relay from the battery.
What do I need to do, to get rid of the relay board all together, and to simplify the wiring? |
Marv's3.6six |
Oct 28 2007, 12:37 AM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
Great question............Because I was thinking the same thing, and doing a little research on it.
4 Governor 52 Rear window heater 55 Relay heater blower 74 Relay for power supply 75 Relay for gasoline pump 90 Regulator plate 91 Fuses for rear window heater, heater blower, gasoline pump I have a DME car (was 3.2 now going to 3.6) and its all wired around the relay board as best I can tell. Don't have window heater, heater blower, and the fuel pump is wired thru old fog light circuit. What do we really need the relay board for? what is 4 Governor & 90 Regulator plate used for? Attached thumbnail(s) |
Hammy |
Oct 28 2007, 01:39 AM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
90 Regulator plate is the relay board itself I believe. Marv how did you wire up the pump to the fog light circuit? Does the fog light switch turn on the pump?
ejm |
Oct 28 2007, 06:20 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The "govenor" is the voltage regulator and 90 is the board itself. If you don't need the FI relays the board is easy to eliminate. Many wires are just spliced together including the oil light, backup lights, starter solenoid, tach signal and coil power. Here's a list of what goes where.
T14 Connector 1 Starter solenoid power in from igntion switch 2 From voltage regulator to alternator warning light 3 Power in for backup lights 4 Power out to backup lights 5 Out to oil pressure warning light 6 Not used 7 Tach signal out to tach 8 Power in from ignition switch for coil 9 Ground signal from heater fan switch 10 Chassis ground for relays on board 11 Power out to heater fan 12 Battery power in to fuel injection power supply relay 13 Power out to fuel pump 14 Battery power in to fuel pump, heater fan and rear window relays T12 Connector 1 Signal from oil pressure switch 2 Power out to backup light switch 3 Not used 4 Power back from backup light switch 5 Tach signal in from coil 6 Power out to starter solenoid 7 Power out to ignition coil 8 Not used 9 Not used 10 Heater fan jumper wire to T12/11 11 see above/fan can also be powered from this terminal instead of T14/11 12 Power out from fuel pump relay to aux air regulator |
gopack |
Oct 28 2007, 08:37 AM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
WOW that is awesome information EJM I nominate this to the classics thread... Also some one need to DO this and take pics and do a write up... it may be me because the wiring harness is probably going back in next month and why have it if i dont need it.
rick 918-S |
Oct 28 2007, 09:04 AM
Hey nice rack! -Celette Group: Members Posts: 20,489 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm running an internal voltage regulator style alternator from a Volvo. (although I'm still running the board) I like the board for the ease of being able to simply unplug the harness when removing the engine. Eventually I'll get different plugs.
It's a Bosch. Of course mine is on a 928 engine. If I have time I'll see if there is a way to use the bosch on the type IV. This will allow the elimination of the "Governor. |
Marv's3.6six |
Oct 28 2007, 09:49 AM
90 Regulator plate is the relay board itself I believe. Marv how did you wire up the pump to the fog light circuit? Does the fog light switch turn on the pump? Yes it does, its a great theft deterent as there is no way to start the car without the fog light switch on! BTW I don't have foglights, and it was a simple rewire. |
hcdmueller |
Oct 28 2007, 12:50 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I'm running an internal voltage regulator style alternator from a Volvo. (although I'm still running the board) I like the board for the ease of being able to simply unplug the harness when removing the engine. Eventually I'll get different plugs. If you are running an internally regulated alternator and the relay board how did you bypass the external regulator on the board? Just wondering because I am getting ready to put a high amp alt from a newer VW and they are all internally regulated. I would like to keep the board for now for your reasons and some others. |
ejm |
Oct 28 2007, 03:26 PM
If you are running an internally regulated alternator and the relay board how did you bypass the external regulator on the board? Just wondering because I am getting ready to put a high amp alt from a newer VW and they are all internally regulated. I would like to keep the board for now for your reasons and some others. With the regulator inside the alternator you need just two connections. The heavy output wire can go to the starter post like it does now or you can run it directly to the battery. The other wire is for the warning light and gets connected to the wire at T14/2 on the relay board. Remove the old alternator with it's harness and the voltage regulator from the board. |
chris914 |
Oct 28 2007, 04:37 PM
Is it possible that there is both now?
How can I tell if there is a regulator inside the alternator now. If not how do I get the correct alternator with a built in regulator? |
chris914 |
Oct 28 2007, 08:26 PM
Here is the pin out to get rid of the relay board:
T14 Connector => T12 Connector Starter Solenoid: 1 - Yellow => 6 Voltage Regulator Alternator Relay: D+ => Red D- => Brown DF => Green -> 2 – Blue Backup Lights: 3 - Grey/Brown => 2 4 - Grey/Brown => 4 Oil Pressure Warning Light 5 - Green/Red => 1 Tachometer Signal: 7 – Black/purple => 5 Ignition Coil: 8 Black/Red => 7 Ignore pins 6,9,10,11,12,13, and 14 if you don’t EFI or a Heater I’m going to get a new multi-pin-connector and cut off the old ones. T14 Connector 1 Starter solenoid power in from igntion switch 2 From voltage regulator to alternator warning light 3 Power in for backup lights 4 Power out to backup lights 5 Out to oil pressure warning light 6 Not used 7 Tach signal out to tach 8 Power in from ignition switch for coil 9 Ground signal from heater fan switch 10 Chassis ground for relays on board 11 Power out to heater fan 12 Battery power in to fuel injection power supply relay 13 Power out to fuel pump 14 Battery power in to fuel pump, heater fan and rear window relays T12 Connector 1 Signal from oil pressure switch 2 Power out to backup light switch 3 Not used 4 Power back from backup light switch 5 Tach signal in from coil 6 Power out to starter solenoid 7 Power out to ignition coil 8 Not used 9 Not used 10 Heater fan jumper wire to T12/11 11 see above/fan can also be powered from this terminal instead of T14/11 12 Power out from fuel pump relay to aux air regulator |
Lo-Fi Version | Time is now: 7th June 2024 - 07:08 PM |
