Rear Springs, Saggin in the Waggin? |
BiG bOgGs |
Oct 29 2007, 09:10 PM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
My 76 914 looks like it is going up hill. I don't know if this is because the rear springs are old and weak, or that the front is just adjusted to high. What do I need to do to check the front for proper hight. And what do I need to do to check the rear springs for what size they are and then what measurement should I take to see if they are still in spec?
If they do need replaced, is there and easy way to do it, or do I just get the Haynes manual out and do it step by step? Jim |
SLITS |
Oct 30 2007, 11:39 AM
Rears - 90 -100 lbs per inch. Measure free length, put 90 - 100 lbs on spring and measure again . deflection should be 1" - if more they are weak.
Haynes manual is your friend .... no other way than to remove them, compress springs with spring compressor and remove nut on shock rod then release spring compressor slowly. Not a bad job but be very careful. If the cheaper spring compresors are not kept in line, the spring can fly at a high rate of velocity and hurt someone / something. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:51 AM |
