alpha434 |
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains ![]() |
On the wheel side. Driver side wheel. What parts do I need?
Went to Chipotle, made a right turn accelerating, and pop! Engine spins. CV spins. Wheel doesn't. (IMG:style_emoticons/default/wacko.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Ahhhhh, yes, Mc Mexican food ....
Enough of the social commentary (Mc Donald's sold the controlling interest last year). First thing you need to do is chack whether it's the bolts or the CV joint. If it's the bolts, you'll need 4 bolts, 2 plates, and 4 washers. If it's the joint, I believe Eric Shea has 'em. You'll still need the hardware. The Cap'n |
alpha434 |
Yep.
Bad day for my 914 to be my primary car. I can't see down into the trailing arm. But isn't that a splined shaft, anyway? Bolted in by the castle nut under the wheel??? |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Yep. Bad day for my 914 to be my primary car. I can't see down into the trailing arm. But isn't that a splined shaft, anyway? Bolted in by the castle nut under the wheel??? Not at the part where it would break. The most common area for these to go is at the shaft to transmission joint, but there is a reason why some reffer to these as fuses (IMG:style_emoticons/default/headbang.gif) They bolt on at both sides though. |
alpha434 |
It's not at the trans joint. That part is still firmly attached.
The wheel side is where it's broken. How do I get in there to see it? Or do I have to yank it just to look at it? |
PeeGreen 914 |
No... You just have to look into the hole where it goes into the trailing arm. Jack it up and see if the wheel spins without the axle moving. If so you know what you need to do (IMG:style_emoticons/default/wink.gif)
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
You'll have to remove the inner joint from the trans, then undo the castle nut at the wheel, then pull the axle with the splined stub as one unit. Rebuild as necessary, the reinstall. Don't bother trying to remove the axle and leave the stub in place. I tried that for about an hour, gave up and undid the castle nut and had it out in 15 minutes. (IMG:style_emoticons/default/pinch.gif)
Lo-Fi Version | Time is now: 31st July 2025 - 05:26 PM |
