> Optima Battery, Charging
BarberDave
post Nov 5 2007, 03:08 PM
Barberdave
I am getting my 914 ready for winter storage. I have a Optima Red Top Battery.
I have a Sears battery maintainer/ charger will that work on a Optima Battery.
The directions mention every other kind of battery,is there any special things to
do ,or special maintainer I should use. I remember reading some thing about
them requiring some sort of special care. But I forgot what !!!!!!!! I seem to do
that a lot lately. What is your opinion ???????? Dave (IMG:style_emoticons/default/slap.gif)
Replies(1 - 8)
messix
post Nov 5 2007, 04:42 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
float charge 13.2-13.8v at no more than 1amp.
it's a agm battery.
BarberDave
post Nov 5 2007, 05:00 PM
Barberdave
Messix:
What is a float charge??????? Dave (IMG:style_emoticons/default/slap.gif)
orthobiz
post Nov 5 2007, 07:46 PM
I bought a battery charger/tender/minder with my car storage capsule. Came at a discount. The seller says it's the best but it does have a true "float" feature. My battery is on it as I type...ask me in the spring!
Charger
12 Volts, 3 Amp Constant Current
(Equivalent to 6 Amp tapered charger in charging time)
Input 115 VAC (range 90 VAC to 132 VAC)
Suitable for U.S., Canada, other 115VAC countries & Japan (100VAC).
Automatic Cut-off and then true Float.
Can be left connected indefinitely without harming the battery
Increases battery life by de-sulfating the battery
UL and cUL (CSA) Listed
Meets FCC Class B. High level of electro-magnetic interference filtering
Suitable for off-board application.
Size, only 4 ½” x 2 ¼” x 1 ¼”, and very lightweight, only 11 ounces
messix
post Nov 5 2007, 07:57 PM
QUOTE(BarberDave @ Nov 5 2007, 03:00 PM) *
Messix:
a "float charge" is putting just enough current into the battery to keep it "topped off" in the battery's fully charged charged state. you wouldn't want to hit it with 5 amps at 13.5 all the time. as the charge state of a battery gets to it's fully charged limit the resistance to more charge = higher voltage for same amps in. this can damage a battery if not monitored. if the battery has a fault or is left on a charger that doesn't have a automatic charge setting it could over heat gas and explode.
so short answer: float charge = storage charge.
Pat Garvey
post Nov 5 2007, 08:13 PM
Do I or don't I...........?
QUOTE(orthobiz @ Nov 5 2007, 08:46 PM) *
Charger
Hey biz,
You aren't charging the battery while the car is in the capsule, are you?
Pat
orthobiz
post Nov 5 2007, 10:20 PM
[quote name='Pat Garvey' date='Nov 5 2007, 09:13 PM' post='964013']
[quote name='orthobiz' post='964004' date='Nov 5 2007, 08:46 PM']
Hey biz,
Pat
[/quote]
Nah. Battery is out of the car. I worry about the stupid clock wearing out and I worry about some type of incendiary event with a toasty blown up Optima. Heck, I worry about wayward spiders getting shredded in the fan and splattering on my bumper!
Paul
BarberDave
post Nov 6 2007, 07:38 PM
Barberdave
So if I take it to Auto zone and make sure it is fully charged,then take it home
and put it on the Maintainer ,it will be O.k. till March. RIGHT??????
messix
post Nov 6 2007, 10:18 PM
QUOTE(BarberDave @ Nov 6 2007, 05:38 PM) *
yup
- Lo-Fi Version Time is now: 16th April 2026 - 03:59 PM
