| slackin' at work |
Nov 8 2007, 02:37 PM
i should be working ![]() ![]() Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
my car has a 009 and I know it is not doing me any favors.
I NEED to replace it with something... and Im eventually going back to FI. so my question is, can I run a stock distributor with dual carbs? Should I take the trigger-points out until Im ready to go FI? of course I don't have the stock distributor, so before I buy one Id like to know if it's OK to run it until I make the swap. (IMG:style_emoticons/default/beer.gif) -chris |
| TravisNeff |
Nov 8 2007, 02:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
yes you can run a stock distributor, I'd leave the trigger points in as you will get a bunch of crap in your distributor from the hole where the points were. Rig up a retard line in your intake manifold too.
| anderssj |
Nov 8 2007, 02:49 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,779 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
I've heard that the stock distributor from a 1.8L is a good choice, but I have no personal experience (still running a bosch 050 with DRLA40s).
Best, |
| slackin' at work |
Nov 8 2007, 03:53 PM
thanks guys for the thoughts.
I was just about to buy an SVDA dist. from aircooled.net (I was at the online checkout) and realized it was dumb if I was just going to have to find a stock one once I went to make the swap. (IMG:style_emoticons/default/teef.gif) |
| andys |
Nov 8 2007, 04:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
When I made a Weber carb swap on my 2.0L some 30+ years ago, I used the stock distributor.
Andys |
| 914Mike |
Nov 8 2007, 07:23 PM
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I've heard that the stock distributor from a 1.8L is a good choice, but I have no personal experience (still running a bosch 050 with DRLA40s). Best, Yep, the one from almost any 1.8 is mo' better than any 009! (IMG:style_emoticons/default/barf.gif) (Or the one from a 2.0 bus motor for that matter. ) I'm running the 1.8 dizzy on my 2056 with the baby Webers, set the max advance @ 27 deg. and it's good to go, nice idle 'cause the mechanical advance has lots more degrees than a 009. I never hooked up the retard side of the dashpot, but the advance side is connected to the Weber vac ports... (IMG:style_emoticons/default/beer.gif) |
| BarberDave |
Nov 9 2007, 05:20 AM
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I use a 50 with a Petronics (sp) unit, with 40's since 2000 ,the only trouble was of my own makeing. I.E. left the ignition switch on burnt the Petronics out. Good luck Dave (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 11th March 2026 - 01:19 PM |
