mikeyboy_85 |
Member ![]() ![]() Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 ![]() |
is there ment to be contact between the lever on the switch and the base of the pedals at all time? What would be even better is if someone could show me some pics of what its ment to look like with the pedal pressed and without the pedal pressed . .
cheers michael |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
There is supposed to be contact all the time. The switch is spring-loaded in the "turn the lights on" direction, so when nothing is moving the little arm back the lights will be on. The arm of the switch rides on the near side of the washer on the brake pushrod, and when the pedal is up (and the rod is moved back) the switch arm is moved and the light goes off.
Common mistake. --DD |
mikeyboy_85 |
how is the switch ment to be attacted to the pedal? i see something that kinda looks like a hose clamp but it doesn't seem to be able to attach to the lever of the switch, could u please post a pic ?
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,835 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
The switch is attached to the pedal cluster, it is activated by a large washer that's on the master cylinder plunger.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
when in doubt consult your haynes. on p.129, fig 9.24 shows the correct orientation of the actuating arm. section 30 (same page) discribes removal, installation, and the adjustment of the switch.
Lo-Fi Version | Time is now: 19th July 2025 - 03:23 AM |
