Another pair of pants stained with grease while driving..., ...have any of you had this happen in your 914? |
RoadGlue |
Nov 9 2007, 10:31 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
So you get dressed, put on some nice pants and head out onto the open road in your 914. You get to your destination and notice that you have a silver dollar sized grease spot near the bottom of your right leg. You think it's odd, but don't put two and two together until it starts to become a regular occurrence.
I know what the cause is, but I want you to guess first. Then I'll ask for the solution, though I think I know what that is too. Any takers? |
grantsfo |
Nov 9 2007, 10:38 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
So you get dressed, put on some nice pants and head out onto the open road in your 914. You get to your destination and notice that you have a silver dollar sized grease spot near the bottom of your right leg. You think it's odd, but don't put two and two together until it starts to become a regular occurrence. I know what the cause is, but I want you to guess first. Then I'll ask for the solution, though I think I know what that is too. Any takers? I dont know as I dont wear pants when I drive my car. |
So.Cal.914 |
Nov 9 2007, 10:39 PM
Speedo cable?
So.Cal.914 |
Nov 9 2007, 10:41 PM
So you get dressed, put on some nice pants and head out onto the open road in your 914. You get to your destination and notice that you have a silver dollar sized grease spot near the bottom of your right leg. You think it's odd, but don't put two and two together until it starts to become a regular occurrence. I know what the cause is, but I want you to guess first. Then I'll ask for the solution, though I think I know what that is too. Any takers? I dont know as I dont wear pants when I drive my car. (IMG:style_emoticons/default/biggrin.gif) ... (IMG:style_emoticons/default/huh.gif) |
Jerry |
Member Group: Members Posts: 413 Joined: 7-April 05 From: Conroe, Texas Member No.: 3,892 Region Association: None |
I dont know as I dont wear pants when I drive my car. Does anybody??? Naked Porsche driving!!!! My favorite!! |
Thack |
Nov 9 2007, 10:58 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
Master cylinder leak?
RoadGlue |
Nov 9 2007, 11:16 PM
Speedo cable? Ding ding ding! I have to assume that the inner seal on the speedo drive is toast, so gear oil is traveling all the way up to the speedo, where it then drips down on to my leg. Pretty annoying! (IMG:style_emoticons/default/smile.gif) |
2-OH! |
Nov 9 2007, 11:39 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Yep...Had to fix the same problem myself...Take that angle drive off, reseal and don't forget to drain the cable...Problem solved...
2-OH! |
Wilhelm |
Nov 10 2007, 03:48 AM
Member Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
So you get dressed, put on some nice pants and head out onto the open road in your 914. You get to your destination and notice that you have a silver dollar sized grease spot near the bottom of your right leg. You think it's odd, but don't put two and two together until it starts to become a regular occurrence. I know what the cause is, but I want you to guess first. Then I'll ask for the solution, though I think I know what that is too. Any takers? My pants get stained every time I drive my 914!!!! (IMG:style_emoticons/default/w00t.gif) Oh wait............that's not grease. (IMG:style_emoticons/default/wub.gif) |
TheCabinetmaker |
Nov 10 2007, 05:58 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Speedo cable? tranni fluid is traveling all the way up the cable to the cockpit and leaking on your pants? You guys are joking right? Your master cylinder is leaking. Pull up the carpet and you'll see the pedal cluster soaked in fluid.
RoadGlue |
Nov 10 2007, 12:08 PM
Speedo cable? tranni fluid is traveling all the way up the cable to the cockpit and leaking on your pants? You guys are joking right? Your master cylinder is leaking. Pull up the carpet and you'll see the pedal cluster soaked in fluid. My brakes are working fine. I've stuck my head (and hands) under the dash and the bottom of the speedometer and part of the dash is lightly covered with gear oil. Also, I had my pedal board out just this week to lube the cluster a bit, and everything was dry there. It's perfectly reasonable to think that a spinning sheathed cable could wick oil up to the gauge. In fact, it's hard to imagine how a leaky MC could squirt brake fluid past the dust seal, around the pedal board and carpet and end up on the top part of my leg. (IMG:style_emoticons/default/tongue.gif) |
TheCabinetmaker |
Nov 10 2007, 12:36 PM
I've seen lots of mc's leak fluid into the pedal cluster and even soak the carpet. That little rubber dust cover ain't gonna stop brake fluid. I guess its possible for the speedo cable to wick tranni oil to the speedo, but i gotta see it to believe it. Call me a doubting thomas if you will.
RoadGlue |
Nov 10 2007, 12:38 PM
I've seen lots of mc's leak fluid into the pedal cluster and even soak the carpet. That little rubber dust cover ain't gonna stop brake fluid. I can see that for sure, but I can't see how it would leave spots on the top side of my pants, or make my speedo and dash greasy. |
TheCabinetmaker |
Nov 10 2007, 12:45 PM
Your first post said the "bottom of your right leg". I read that as the cuff of your pants, not the "top side of your pants" A leaky mc will soak the carpet and ruin the heel of your right shoe and the cuff of your pants. Regardless, ruining your clothes sucks no matter how it gets there. (IMG:style_emoticons/default/sad.gif)
RoadGlue |
Nov 10 2007, 12:47 PM
Your first post said the "bottom of your right leg". I read that as the cuff of your pants, not the "top side of your pants" A leaky mc will soak the carpet and ruin the heel of your right shoe and the cuff of your pants. Regardless, ruining your clothes sucks no matter how it gets there. (IMG:style_emoticons/default/sad.gif) Ha! Yeah, um, bottom near the cuff on the top side. My bad for not being more descriptive. Sorry for the confusion there. (IMG:style_emoticons/default/smile.gif) |
TheCabinetmaker |
BTW, speedo angle drive seals are dirt cheap (IMG:style_emoticons/default/biggrin.gif)
Katmanken |
Nov 10 2007, 07:09 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Here's a clue...
Some darn thing is getting low on fluid. The number of possible things is very limited..... Find the thing and you have it..... And here is another clue, They all smell different....... And, no, the blinker fluid has no smell... Ken |
So.Cal.914 |
Nov 10 2007, 07:38 PM
And here is another clue, They all smell different....... And, no, the blinker fluid has no smell... Ken I don't know, that blinker fluid thing smells a little fishy to me... (IMG:style_emoticons/default/dry.gif) |
Pat Garvey |
Nov 10 2007, 08:09 PM
So you get dressed, put on some nice pants and head out onto the open road in your 914. You get to your destination and notice that you have a silver dollar sized grease spot near the bottom of your right leg. You think it's odd, but don't put two and two together until it starts to become a regular occurrence. I know what the cause is, but I want you to guess first. Then I'll ask for the solution, though I think I know what that is too. Any takers? I dont know as I dont wear pants when I drive my car. Know what you mean, but you need to REALLY careful when adjusting the seat, particularly if you're 60! Pat |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:20 PM |
