| jimkelly |
Nov 11 2007, 08:12 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
what years fit 914?
what is the first year 911 had vented rotors? which 911 struts bolt directly onto 914 suspension? and the differences between different year 911 front suspensions? thanks jim BTW - brad at 914club is selling billet 4 lug hubs for vented rotors $425 set - tempting for sure. |
| lotus_65 |
Nov 11 2007, 08:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
There's some good info on the Pelican site.
I suppose it could be better if someone put some serious time into it. Hope someone does it! |
| jimkelly |
Nov 11 2007, 09:14 AM
thanks
jim |
| flesburg |
Nov 11 2007, 09:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
Probably the reason no one has is because they are an EASY exchange.
The only differences are the internal splines for the torsion bar. You can exchange a complete front end, or keep your rack, or just exchange the struts and spindles and hubs, and any combination. I replaced the stock 914 unit with just struts, hubs and brakes, with one from a SC on one car, and replace the whole unit (including steering rack) from a 911 Turbo in another car. Straight bolt up process. |
| smontanaro |
Nov 11 2007, 09:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
There's some good info on the Pelican site. From reading this I take it my '70 914/6 is mostly the same as similar vintage 911 setups save for the different style parking brake? Thx, Skip |
| Richard Casto |
Nov 11 2007, 09:56 AM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
While researching the purchase of my 911 front suspension for my 914, I started a page on the 914 wiki for this topic.
http://www.roadglue.com/wiki/index.php/911_front_suspension |
| JPB |
Nov 11 2007, 02:47 PM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Easy enough and yes birdboard has all the info.
I would say: If they black, don't look back, If they other, go run to yo muder 3" calipers, take me to heaven, if they 3 1/2" price calipers before hand racers like three, thats plane to see but for yo teener rocket, dig deep in yo pocket! If yo hands still in pocket, and its there much to long, you ain't doin no work, you be strokin that chlong! AAAh, words of wisdom care of JPB (IMG:style_emoticons/default/beer.gif) |
| neo914-6 |
Nov 11 2007, 03:30 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
what years fit 914? what is the first year 911 had vented rotors? which 911 struts bolt directly onto 914 suspension? and the differences between different year 911 front suspensions? thanks jim BTW - brad at 914club is selling billet 4 lug hubs for vented rotors $425 set - tempting for sure. There are tons of threads here on this subject, search "strut" and "Eric Shea" (IMG:style_emoticons/default/smile.gif) |
| Eric_Shea |
Nov 11 2007, 03:37 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Speak of the devil... here I come (IMG:style_emoticons/default/happy11.gif)
QUOTE From reading this I take it my '70 914/6 is mostly the same as similar vintage 911 setups save for the different style parking brake? Well, in saying that you tend to marry front and rear suspensions and then the answer is no. The rear suspension, because of our mid-engine configuration, is totally different from a 911. It is all 914 with the exception of calipers, rotors, hubs and stub axles (CV's and axles too) When you get down to basics, yes... 48mm pistons, same calipers up front and both share 38mm pistons in the rear albeit on totally different calipers. You're about 99% accurate on the front end. The only difference I can see between a 1970 911T front end and a 1970 914-6 front end is the torsion bars. The 914-6 has special torsion bars that have the spline count of a 911 yet the spring rate of a 914. NOW... why they simply didn't use 914 A-arms is beside me. It could very well be these suspension modules came "complete" and for economies of scale, they would be interchangable with the 911 bits. I have a factory video from that period which shows them installing a front suspension complete (brakes, struts etc.) on a 911. So, I would guess they simply used a completed 911 front suspension spec'd with 914-6 17mm weighted bars. John is right... simply take these bolts out yank/replace and install those bolts. No conversion could be more straight forward. However, there are a few "varieties" to choose from. I like to keep 914 a-arms for street and narrow bodied cars. This means you can probably get by with a simple strut purchase and swap. If you're going road racing I like the 911 arms as they afford a larger variety of t-bars. I like 911T Boge struts (914-6 struts) for street and/or narrow cars and either vintage Koni/Bilstein struts with the 3.5" ears or later Boge with the 3.5" ears for wide body/racing cars. Also, get the a-arms for wide/racing cars as explained above. The 3.5" spacing allows the use of many upgraded calipers (S, A, Carrera etc.) There probably should be a well defined list available for those interested in this fairly common process. I agree. Basically: Emulate a 914-6 if you want a nice set-up for a narrow bodied street car and, emulate a 914-6/GT for more advanced use and performance. (IMG:style_emoticons/default/wink.gif) |
| Air_Cooled_Nut |
Nov 11 2007, 06:25 PM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
There are tons of threads here on this subject, search "strut" and "Eric Shea" (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/slap.gif) And your post is exactly why he has a valid post. Think about it. Put all the information into ONE POST (or fact sheet) instead of having to waste time searching hundreds of posts. (IMG:style_emoticons/default/idea.gif) |
| McMark |
Nov 11 2007, 07:27 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
BTW - brad at 914club is selling billet 4 lug hubs for vented rotors $425 set - tempting for sure. I have a moral objection to these hubs. The design is great, and they work well. No doubt about that. The objection I have relates to how the production of those hubs was financed. (IMG:style_emoticons/default/dry.gif) |
| jimkelly |
Nov 11 2007, 08:39 PM
| John |
Nov 11 2007, 08:41 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I prefer the latest (up to 1989) 911 front suspension (complete) that you can buy.
The parts are newer. I also prefer BOGE struts if you have a choice. There is a better selection of inserts. |
| PeeGreen 914 |
Nov 12 2007, 01:10 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
Eric
Don't you suppose the reason they used all 911 stuff of the 6s is because they were assembled in the Porsche factory? I would think they just used what was on hand rather than get them from VW. That would be my thinking anyway. |
| Brando |
Nov 12 2007, 02:28 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
It's easy...
Remove wheels. Unbolt A-arms and steering rack + cross-member from 911. Remove nuts on top of the struts - complete suspension. SWAP rubber-bushed input splined steering shaft from your 914 to the 911 steering rack. Bolt in A-arms, steering rack + cross-member from 911 into 914. Attach nuts on top of the struts - complete suspension. Appicable years: 1965-1988. |
| Cap'n Krusty |
Nov 12 2007, 02:43 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
You really wouldn't want to use 1965-1968 struts, as the ball joints are different (and they regularly wear out, no fun at $150 + apiece) and you have to change the A-arms, as well. The hub/caliper/wheel offsets are different, too. The Cap'n
| Aaron Cox |
Nov 12 2007, 03:58 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
and avoid hydro pneumatic struts!
| 913B |
Nov 18 2007, 12:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
and avoid hydro pneumatic struts! speaking of hydro shocks. I picked up a set of 3" boge struts. I unscrewed the strut and found out what they believe to be hydro shocks. Are they bad ?? I can just remove the valves and oil and drop in a Bilestein shock right ? Sorry if this is a hi-jack. |
| neo914-6 |
Nov 18 2007, 03:05 AM
There are tons of threads here on this subject, search "strut" and "Eric Shea" (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/slap.gif) And your post is exactly why he has a valid post. Think about it. Put all the information into ONE POST (or fact sheet) instead of having to waste time searching hundreds of posts. (IMG:style_emoticons/default/idea.gif) I have thought about it and have occasionally done something about it. I have 30 links alone on this thread I have links upon links in other threads. Jim has a good conversion link list in his signature I've referred to. In general, it's easy to ask questions or make suggestions but SOMEONE or several members will need to donate hours of data mining, organizing, and editing to make a FAQ or tech worthy post. |
| Eric_Shea |
Nov 18 2007, 10:51 AM
QUOTE I unscrewed the strut and found out what they believe to be hydro shocks. Are they bad ?? Yes. But, what makes you think they are hydros? Pics would help. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:21 AM |
