mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Hi,
If you have these, can you tell me the measurement for the 20-bolt holes on the halves? Preferably measure is across between 2 opposite holes. Reason is I just got a bunch of parts of HRE wheels, and can barrels of BBS interchange, or maybe that's what I already have. I'm going to find halves that make up the right offset for me and sell off the rest. Thanks, Mark S. Attached image(s) ![]() |
zig-n-zag |
Member ![]() ![]() Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 ![]() |
mskala, It looks to be 13-5/16". I don't know if your HRE wheel centers are interchangable with BBS halves, but BBS centers measure as close as I can tell is 14-1/8". Hope it helps you.
mskala |
Thanks, but I don't understand your numbers. For BBS, which number is bolt-hole to opposite bolt-hole? I have to measure mine tonight, I have a bunch of un-assembled parts so it will be easy.
Thanks, Mark S. |
mskala |
Ah, I think I get it. Your 13 5/8" is exactly what I have, using the outer edge of the holes. And the diameter of the HRE center itself is about 14 1/8". So HRE and BBS
parts should play well together (IMG:style_emoticons/default/aktion035.gif) Thanks a lot |
blabla914 |
I like primer ![]() ![]() Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None ![]() ![]() |
Hey Mark.
Nice score on the wheels. What are you putting together. Hopefully I will have my motor sorted by spring and I'll be around some. Kelly |
mskala |
Hi Kelly,
Always looking for newer/better/lighter wheels. If possible I'll set these up as 16x7 with appropriate offset for stock-fender car, otherwise I'll maybe sell them off. |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
If you can come up with a set of 16X8s and 9s for my flared car on the cheap... Let me know. I need a set desperately.
Clayton |
Lo-Fi Version | Time is now: 15th June 2024 - 07:27 PM |
