Oil pres. sender on 4 cyl..., Washer or not? |
Mike D. |
Mar 18 2003, 11:17 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
This may sound like a silly question, but is there suposed to be a seal or crush washer between the case and oil pressure sender (stock)? (IMG:style_emoticons/default/huh.gif)
-Mike D. |
Mike D. |
Mar 18 2003, 12:36 PM
Anybody...? really, I have to do this today...
Porsche Rescue |
Mar 18 2003, 12:43 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
My memory says no. I think the sender is a tapered thread (pipe thread). You can probably tell by installing to reasonable degree of torque. I think you will see that it does not bottom out so sealing ring would not help. I would not bet the farm on the above advice but hope it helps some.
porschewiz |
Mar 18 2003, 12:58 PM
Newbie Group: Members Posts: 29 Joined: 11-March 03 Member No.: 412 |
Definatilly not .... its tapered
I don think you'll be able to see the treads with the sheet metal on. If its leaking its probably where the plastic and metal meet and once they are really leaking it nomally will make it look like the contact is leaking oil and you shouldn't use teflon tape on the threads. |
Lawrence |
Mar 18 2003, 01:13 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
When I put a new sender in the Bumblebee.. I don't think I used one.
-Rusty |
Dave_Darling |
Mar 18 2003, 01:28 PM
There definitely should not be a seal or gasket. It does use tapered "pipe" threads.
--DD |
Zeke |
Mar 18 2003, 01:38 PM
Never left, but not right.... Group: Members Posts: 382 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
10-4, no seal.
porschewiz |
Mar 18 2003, 01:39 PM
Hay Dave.... Are you on the clock? What do you accually do for NASA? LOL . That website I was talking about ealier with you was called mike's tech page it had some good info on the BMW brakes and the D-jet (I think you wrote.) Is this website still around?
Mike D. |
Mar 18 2003, 01:55 PM
Thanks everyone!
-Mike D. |
Dave_Darling |
Mar 18 2003, 03:46 PM
Sorry, but I don't remember a "Mike's Tech Page". There was Tim Jones' 914 Fan Page, which should still be available at http://www.914fan.org . There's a lot more info out there now--for instance, Brad Anders D-jet pages have just about everything that anyone knows about D-jet EFI. http://members.rennlist.com/pbanders .
--DD |
porschewiz |
Mar 18 2003, 03:52 PM
It might have been Tim's...... Has CRS syndrome and sometimers
Lo-Fi Version | Time is now: 8th June 2024 - 10:25 AM |
