More on shop heaters |
Joe Bob |
Dec 31 2003, 10:34 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Since I buy diesel in bulk for my F350....I decided to look for a diesel fired space heater for the workshop. WTF...only the Limey's are using them?
J P Stein |
Dec 31 2003, 10:37 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I have one. Doesn't give me a headache & punches out a fair amount of heat. Wanna pic?
Joe Bob |
Dec 31 2003, 10:47 PM
DuckRyder |
Dec 31 2003, 10:49 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
got a 55,000 btu multi fuel from lowes.
It rocks, thing will heat a 2 car garge in no time and its great for installing cam gears too. |
GWN7 |
Dec 31 2003, 10:53 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
I've got one in the garage....never use it. Propane fan powered one for startup and a wood stove for long term heat. Have a natural gas furnace that I'm putting in this summer. (for constant heat)
If your looking search for "oil burners" |
Joe Bob |
Dec 31 2003, 10:59 PM
I did a Diesel Space Heater Google search and all the links were in the UK.....
Are they banned here? I know used oil heaters are..... Oh and what is #1 fuel? The ones that use kerosene also use that......none seem to use Diesel #2...... |
J P Stein |
Dec 31 2003, 11:28 PM
It's made by Toyotomi......sounds 'merican, eh.
Model is Toyoset Omni 230. Prolly heat up that little shop of your'n. I it use for a quick warm-up of my shop along with the pellet stove. Attached thumbnail(s) |
Joe Bob |
Dec 31 2003, 11:50 PM
Cool,,,,ever try to run it on Diesel instead of Kerosene?
J P Stein |
Dec 31 2003, 11:58 PM
Nopers, just Kerosene. Ain't much different than diesel, tho...."I think". (IMG:style_emoticons/default/confused24.gif)
BTW, 23k BTUs.....first time I've read the directions (IMG:style_emoticons/default/blink.gif) |
GWN7 |
Jan 1 2004, 12:50 AM
Those also say "don't use in enclosed spaces" They will burn up all the O2 in the air if your garage is air tight........
The used oil burner furnaces will burn diesel..... |
Joe Bob |
Jan 1 2004, 12:53 AM
Yeah I know about the venting....open the bottom of the garage door, and usck in cold freah air, heat and CO goes out the top. But filling propane tanks is a pain......I have a 200 gallon diesel tank that I would like to use.....
Crap....looks like propane..... Happy New Year BTW..... (IMG:style_emoticons/default/mueba.gif) |
GWN7 |
Jan 1 2004, 12:59 AM
well I wonder what it would cost to ship the one I have in my garage to you......only thing I use it for is to hold my compressor up.........
It's about 4' tall and 2' X 2' wide diesel is heating oil or can be used as heating oil ( I've used it).... |
Joe Bob |
Jan 1 2004, 11:18 AM
Weigh it.....go to www.ups.com and use 93109 zip code.....
BTW....what is "#1 fuel"? Google did not find anything..... |
steve@ottosvenice.com |
Jan 1 2004, 11:31 AM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
See page 476 in their Catolog http://www.westmarine.com/
Joe Bob |
Jan 1 2004, 11:45 AM
Thanks Steve....what up on that muffler we talked about?
DuckRyder |
Jan 1 2004, 11:57 AM
Check this out as well. Never ran it on diesel, but it says it will. Wonder how it would smell burning diesel?
They have larger and one smaller as well. I've tryed a smilar btu double propane heater and this works lots better for about the same money. http://www.lowes.com/lkn?action=productDet...000000234-R55BT (it may make you enter a zipcode) (IMG:http://images.lowes.com/product/043593/043593350749.jpg) |
Joe Bob |
Jan 1 2004, 12:42 PM
I already have something like that powered by propane....damn thing puts out TOO much heat.
Jan 1 2004, 12:49 PM
Group: Posts: 0 Joined: -- Member No.: 0 |
How safe are those when you use chemicals (brake cleaners) and welding near it. I have a fear of fire in the garage.
GWN7 |
Jan 1 2004, 01:47 PM
I think #1 refers to the grade of fuel...sort of like winter grade, will flow in extreem cold temps.........
The units that I have used have a circular wick enclosed inside the heat exchanger. The "Carb" drips fuel at a constant rate on to the wick. Higher heat demand = more fuel dripped. The burnt fuel/ gases go up the chimney and the heat is radiated out from the heat exchanger. Some have fans that help move the heat off the unit. Like any open flame type furnace, if the combustion level of whatever you are cleaning with reaches the lower explosion limit it will ignite. Too little PPM (Parts Per Million) no ignition, too many PPM no ignition either. The range between the two is called the explosion range or limit. Any use of brake cleaner or any other solvent should be done in a open air enviroment so that you don't end up breathing the fumes. Welding shouldn't be any problem. As the fuel is enclosed inside the heat exchanger. You would have to be welding inside it to ignite the diesel. The best unit to put in is a forced air electric unit. Clean, safe. 220V power. But you can't write off the costs of the electricty against your taxes like the diesel can be. (IMG:style_emoticons/default/cool_shades.gif) |
Joe Bob |
Jan 1 2004, 02:20 PM
40 degrees is OK when you are cutting wood, exercising or such.....40 and under is freaking cold when wrenching and BSing in the garage......we also get freezes here....... (IMG:style_emoticons/default/bootyshake.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 09:22 PM |
