Noisy valves?, 2.0 |
Bogaat |
Nov 17 2007, 10:37 AM
Member Group: Members Posts: 195 Joined: 8-January 07 From: Charleston, SC Member No.: 7,436 |
I just adjusted my valves after breakin using the captains instructions. Only two had to be adjusted as they were tight. I haven't really listened to the engine idle too much and am paranoid that the valves are loose. When I put my head down low next to the engine, I hear the valves doing their thing. I am not too familair with the sounds these things are supposed to make as I am just getting this thing going. It sounds like there are a couple guys with small hammers down there making music. Sound right? If not, how long should I let these guys cool down before I check adjustment again? I typically wait overnight on my bug, but I would like to do this later today. 6 hours? Thanks guys (IMG:style_emoticons/default/beer3.gif)
toon1 |
Nov 17 2007, 01:33 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
They are not supposed to be that loud. You should hear them tapping but not loudly.
Where any of the adjusters way out of whack ( did you have to back any way out to make them right)? You mentioned they where tight, How tight? That is a sign the engine got hot. |
TheCabinetmaker |
Nov 17 2007, 02:00 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
6 hours "should" be adequate. Exhaust leaks at the head can sound like loud tappets also. I like to retorque them after first run anyway whenever I have them off.
rjames |
Nov 17 2007, 03:29 PM
I'm made of metal Group: Members Posts: 3,960 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE Exhaust leaks at the head can sound like loud tappets also. I thought my engine was on it's way out because of how noisy it was. It turned out to be an exaust leak. Check your exhaust stud nuts/bolts while your under there. |
thomasotten |
Nov 17 2007, 03:31 PM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I just recently got my 2056 kit going, and that was the first thing I noticed, loud valve train. I have checked the valve adustment twice already.
Bogaat |
Nov 27 2007, 10:09 AM
QUOTE Exhaust leaks at the head can sound like loud tappets also. I thought my engine was on it's way out because of how noisy it was. It turned out to be an exaust leak. Check your exhaust stud nuts/bolts while your under there. That was it. Those things loosened up pretty good after the break in! Much better now (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 01:57 PM |
