PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
I would appreciate it if someone could post the overall length of their /6 oil dip stick. I need to confirm mine is correct. Thanks
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
I'm a little over 5'10" (IMG:style_emoticons/default/av-943.gif)
(IMG:style_emoticons/default/blink.gif) Oh, you ment the other dip stick..... It is just over 13" in length. That includes the loop. |
thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
Mines even shorter than his... (IMG:style_emoticons/default/sad.gif) just over 9"
(IMG:http://thesey.com/pictures/dip1.jpg) (IMG:http://thesey.com/pictures/dip2.jpg) (IMG:http://thesey.com/pictures/dip3.jpg) (IMG:http://thesey.com/pictures/dip4.jpg) (IMG:http://thesey.com/pictures/dip5.jpg) |
smokey |
Senior Member ![]() ![]() ![]() Group: Members Posts: 533 Joined: 15-June 07 From: Freedom Ca Member No.: 7,816 Region Association: None ![]() |
here is a ???????
Attached image(s) ![]() |
smokey |
12 inches .
PRS914-6 |
OK guys, now this turned interesting......My overall length is 11 7/8. Now that we have some differences and different shape dip sticks, I need more measurements.
Make sure that you have an original tank\neck and original stick and not aftermarket. Need: Overall length Bottom of loop to full mark Bottom of loop to add mark Here is a pic. of what I have. No guarantee it's original (why I am checking) ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,819 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
The critical measurement is from the bottom of the loop, at the little clip that hooks on the tube inside the filler neck.
There are some later dipsticks that don't have that clip. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Cap'n Krusty |
Excuse me? Not to change the topic, but Slick 50 AND K&N? On the same car? Pssst. Come over here, I have a bridge, and I'm gonna make you a REAL sweet deal ..............
The Cap'n |
thesey914 |
Please don't make fun of me...or I'll tell my mum (IMG:style_emoticons/default/smile.gif)
There is a std MAN filter inside, don't know about the slick50 -stickers were already on the air housing when I picked it up. I quite like them... |
PeeGreen 914 |
OK guys, now this turned interesting......My overall length is 11 7/8. Now that we have some differences and different shape dip sticks, I need more measurements. Make sure that you have an original tank\neck and original stick and not aftermarket. Need: Overall length Bottom of loop to full mark Bottom of loop to add mark Here is a pic. of what I have. No guarantee it's original (why I am checking) ![]() This is exactly what I have. My measurement is the same. |
PRS914-6 |
thesey914 |
so has anyone got a known original six dipstick as a benchmark reference
PeeGreen 914 |
Mine is.
I measured two 6'er dipsticks and they both measured the same, 165mm is the distance between the where the dipstick clips on the tube and the MAX level mark.
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
As far as I know mine is original!
Attached thumbnail(s) ![]() ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,289 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
So, Paul S & James, both of yours seem to show the clip as being open so that it can hook on to the inner tube and make a positive stop. The others show the clip as closed which may allow them to be inserted too far.
Can we get a series of dimensions in mm from the stop to the tip; these should be the critical dimensions. Perry says the first dimension from the stop is 165mm to the full mark. What are the rest? |
PRS914-6 |
The only mark on the "real" ones I have is MAX.
I have the original that came in my 6, and a new one I got from Porsche, and except for the silver plating on the original one and the yellow plating on the new one, they are identical. There are no part numbers, and this part is expensive. There's a cheaper 911 ones that will work, but the MAX mark has to be changed. |
Lo-Fi Version | Time is now: 2nd July 2025 - 07:23 PM |
