Need some special /6 engine tools, can ya help me? |
Dr Evil |
Nov 19 2007, 02:17 AM
Hello all, my /6 has developed a problem that is going to require that I remove the cams and thus will need to re-time them. As such, I am in need of a few special tools that may help me get this done.
-The Z block to hold the micrometer -Maybe the micrometer - I have one, I need to see if it will work for this -Mechanical chain tensioner I have the 46m crow foot and the funky socket. Anyone wanna lend me these other special pieces? (IMG:style_emoticons/default/biggrin.gif) |
root |
Nov 19 2007, 07:10 AM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
Hello all, my /6 has developed a problem that is going to require that I remove the cams and thus will need to re-time them. As such, I am in need of a few special tools that may help me get this done. -The Z block to hold the micrometer -Maybe the micrometer - I have one, I need to see if it will work for this -Mechanical chain tensioner I have the 46m crow foot and the funky socket. Anyone wanna lend me these other special pieces? (IMG:style_emoticons/default/biggrin.gif) I've been around for along time, seen alot of different tools.... but I don't think I've ever seen a Z block before. What's it look like? Here's a V block set... |
davep |
Nov 19 2007, 07:34 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I think I have the mechanical tensioner.
type47 |
Nov 19 2007, 07:47 AM
there are some guys who probably have the tools you need to borrow in the baltimore and dc areas but you'd need to post on the boards they frequent. i would recommend dorkiphus.net for guys in the dc area, there are alot of diy mechanics that post on that board. the baltimore guys, i don't really know what board they go to but i'd start with the chesapeake pca site then go from there. a nice guy named manny alban has a concours 914 who i'd bet would help out. dennis howard is another 911 guy who probably has contacts.
VaccaRabite |
Nov 19 2007, 08:11 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Also, you might want to call that guy we got my parts tranny from. He might have the tools you need just down the road in Glen Rock PA.
Zach |
IronHillRestorations |
Nov 19 2007, 09:05 AM
I. I. R. C. Group: Members Posts: 6,730 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I have the Z block, PM me an address.
root |
Nov 19 2007, 10:47 AM
thesey914 |
Nov 19 2007, 11:22 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
SIR tools make this gauge holder 'Z block' .to keep the indicator in correct position when timing the cams
(IMG:http://www.sirtools.com/porsche_tools_files/ap240_small2.jpg) |
root |
Nov 19 2007, 12:04 PM
SIR tools make this gauge holder 'Z block' .to keep the indicator in correct position when timing the cams (IMG:http://www.sirtools.com/porsche_tools_files/ap240_small2.jpg) Oh! Why not just use a universal base dial holder? |
Nov 19 2007, 01:06 PM
You have to measure the valve lift on #1 and #4 intake valve. You could probably find something to put a magnetic holder, but since there's not much ferrous metal on a 911 engine, it's easier to use the Z block. The "Z" block is really more like a L with a tab at the top.
Dr Evil |
Nov 19 2007, 01:10 PM
Root, the Z block bolts to a head stud and holds the mic in place. I dont think the universal one would even work due to there being a shortage of ferrous metal surfaces for the magnet to stick to. Perry and Dave, PM coming and thanks!
root |
Nov 19 2007, 01:37 PM
Suit yourself!
I obviously enjoy doing things the HARD WAY! (IMG:style_emoticons/default/whack_3.gif) |
sww914 |
Nov 19 2007, 01:41 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
My magnetic base like that just happened to have 8mm threads on the rod going into the magnetic base. I removed a valve cover stud and screwed the whole mess right into the cam tower. It was awkward getting the dial indicator into the right place, but it worked.
Lo-Fi Version | Time is now: 8th June 2024 - 12:10 PM |
