OT members list, No longer available? |
Bartlett 914 |
Nov 19 2007, 05:07 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I was unable to find the members list. Maybe I am blind. Is this still available?
TheCabinetmaker |
Nov 19 2007, 05:46 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Sure. Upper right hand corner. next to the search. it says "members"
Bartlett 914 |
Nov 20 2007, 08:42 AM
Sure. Upper right hand corner. next to the search. it says "members" Not quite the same. The names there may not be the same as on the club. In this case, I wanted to look up for posts someone had made. I wasn't sure of the club members name. The current members map is different from what we had and it looks like signing in and inserting your name is necessary to be in the database. No search is available. This database seems worthless. (IMG:style_emoticons/default/unsure.gif) |
TheCabinetmaker |
Nov 20 2007, 10:42 AM
Not members map. Just below the 914 world banner, on the right, it says "help search members calendar" There you will find a list of all current members. Its the same at the "club". When the split took place, the data base was brought over too. Same members with same log ins on both sites (up to that point). Someone correct if I'm wrong please.
SirAndy |
Nov 20 2007, 10:57 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Not members map. Just below the 914 world banner, on the right, it says "help search members calendar" There you will find a list of all current members. Its the same at the "club". When the split took place, the data base was brought over too. Same members with same log ins on both sites (up to that point). (IMG:style_emoticons/default/agree.gif) all right there .... (IMG:style_emoticons/default/bye1.gif) Andy |
davep |
Nov 20 2007, 11:23 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Since the split at about member #7357 member list is not the same.
Some members have changed their login name, and if they did not do so identically on both lists, they would also be different. It kind of depends on who you are looking for. I may be able to help. |
Bartlett 914 |
Nov 30 2007, 11:16 AM
I found my problem. I am using 600 X 800 screen resolution. This blanks all the text under the banner except I can see alander. everything up to and including the letter "C" in calander is missing. If is use a higher screen resolution I see it all.
Edit: It happens when using colors Olympic Blue and below at the lower screen resolution. The top 2 colors work O.K. |
ClayPerrine |
Nov 30 2007, 11:50 AM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I found my problem. I am using 600 X 800 screen resolution. This blanks all the text under the banner except I can see alander. everything up to and including the letter "C" in calander is missing. If is use a higher screen resolution I see it all. Edit: It happens when using colors Olympic Blue and below at the lower screen resolution. The top 2 colors work O.K. User Error... Replace user and hit any key to continue. (IMG:style_emoticons/default/poke.gif) |
pffft |
Nov 30 2007, 12:47 PM
Member Group: Members Posts: 189 Joined: 18-January 05 From: sierra foothills Member No.: 3,465 |
Lo-Fi Version | Time is now: 31st May 2024 - 09:35 PM |
