Before the Rose Bowl, I stripped Blondie..... |
Joe Bob |
Jan 1 2004, 05:43 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
updates as they come up.
(IMG:http://forums.pelicanparts.com/uploads2/11041073000550.jpg) (IMG:http://forums.pelicanparts.com/uploads2/1104a1073000564.jpg) (IMG:http://forums.pelicanparts.com/uploads2/1104b1073000578.jpg) (IMG:http://forums.pelicanparts.com/uploads2/1104c1073000594.jpg) (IMG:http://forums.pelicanparts.com/uploads2/1104d1073000606.jpg) (IMG:http://forums.pelicanparts.com/uploads2/1104e1073000618.jpg) |
Brad Roberts |
Jan 1 2004, 05:46 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Nice tub.
Glad to see you figured out how to create one LARGE image and post it. B |
Joe Bob |
Jan 1 2004, 05:54 PM
Not hard.....
The tub seems to be VERY low miles that just sat out in the weather. Gonna do the Saturn Yellow original color from 73. Fill in the side markers, lose the vinyl on the sail panels and top, fill the dealer imposed antenna hole and windshield squirter holes.....goona leave the front fenders seperators as they ALWAYS crack no matter HOW they are filled or welded. As soon as SOMEONE sends me some adjustable perches and springs (IMG:style_emoticons/default/finger.gif) the ass will come down and the alignment shop will give me some negative caster while bring the front end down to match. Have to do some notching up front for the Carrera struts to get rid of the + caster....... |
Brad Roberts |
Jan 1 2004, 05:58 PM
(IMG:style_emoticons/default/finger.gif) That would be NEGATIVE camber DUMASS...LOL
Caster only effects turn in. B |
Joe Bob |
Jan 1 2004, 06:02 PM
Fat fingers.....where are my perches weasel dick......
Brad Roberts |
Jan 1 2004, 06:11 PM
Everyone (accept me and you) took two weeks OFF. Nobody could get me pricing or parts until Monday.
Sucky.. but what can I do (IMG:style_emoticons/default/confused24.gif) I'm sure GPR has them on the shelf..LOL B |
Joe Bob |
Jan 1 2004, 06:55 PM
HE bailed too.....
seanery |
Jan 1 2004, 07:07 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
how come dave's not a member?
should we invite him? |
LS6/914 |
Jan 1 2004, 08:28 PM
Never leaves the shop member Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest |
RS/SS languishing in the background?
Joe Bob |
Jan 1 2004, 08:32 PM
Yeah that's the paint shop owners kid's SS.....67 I think. Has more rust than Blondie does.....four on the floor and a big block. The owner also has a white 51 vette with red leather interior.
seanery |
Jan 1 2004, 09:23 PM
61 vette?
51 would be rarer than rare! |
Brad Roberts |
Jan 1 2004, 09:28 PM
I have spoken to Dave. He knows we exist and offered to hold an event at his place. I plan to inlude him in the WCC.. if we can get it off the ground.
b |
Eddie Williams |
Jan 2 2004, 12:01 AM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
QUOTE(Brad Roberts @ Jan 1 2004, 09:28 PM) I have spoken to Dave. He knows we exist and offered to hold an event at his place. I plan to inlude him in the WCC.. if we can get it off the ground. b A club discount would rule. Whats the prevailing attitude on their upper strut mounts? |
redshift |
Jan 2 2004, 01:02 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
My brother has a 67 Camaro with 560+ wheel hp, with Tri-power.
Ouch. M |
Brad Roberts |
Jan 2 2004, 01:16 AM
I personally dont like their upper strut mounts.. but it is because I use the real deal. Smart Camber has a screw in one that is 100% heim joint. My dislike is simple: why install plastic when a bearing assembly will work better ??
B |
Eddie Williams |
Jan 2 2004, 01:34 AM
QUOTE(Brad Roberts @ Jan 2 2004, 01:16 AM) I personally dont like their upper strut mounts.. but it is because I use the real deal. Smart Camber has a screw in one that is 100% heim joint. My dislike is simple: why install plastic when a bearing assembly will work better ?? B I understand, but what about a street car? Wouldn't the ride with Smart Camber be a little harsh? |
seanery |
Jan 2 2004, 07:32 AM
Eddie, I think (no experience on this one) that it would feel more precise, but not necessarily more harsh.
rhodyguy |
Jan 2 2004, 09:56 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
how does one create one LARGE image to post? would the 30 second load limit prevent dial-up users from doing this? i tried a short video when i got my 73 running, i was zipping up and down the street, but no go.
kevin |
Brad Roberts |
Jan 2 2004, 12:37 PM
Eddie, those upper mounts have nothing to do with the way your car rides. A bearing allows the car to turn with no bind. If you use plastic or rubber.. the shock shaft tends to turn in the shock and top tries to stay put. All the bearing does is give the shock a solid foundation to function from. When you hit a bump with a rubber mount... the shock pushes on the rubber mount and deflects it up prior to the shock actually doing its job. If you go solid/bearing the shock imediately starts working when you hit a bump.
I could take you for a ride in a roller bearing'd solid upper mounts car with Koni's set on soft and you would think we where in a stock 71 1.7 on 165 tires. All this race type stuff you hear us talking about make the car ride better than ever. B |
Eddie Williams |
Jan 2 2004, 12:48 PM
Makes sense, I'm also trying to learn all this suspension stuff. I assumed that the rubber bushings also absorbed some of the road vibrations, etc. By using ball bearings the shock and spring are doing all of the work, like they should be. I'm trying to build a decent daily driver, I was thinking the bushings would be a good compromise, better than the deteriorating rubber in the car now, but not as "racey" (or expensive) as the bearing setups.
Lo-Fi Version | Time is now: 2nd June 2024 - 05:04 AM |
