Weber carb jets/size? |
partwerks |
Nov 23 2007, 08:40 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The 914 I have with a 2.7 and has carbs is running way too rich as the exhaust smells like gas and about 10 MPG. The main jet is a 145 and the smaller a 65. For some strange reason it has 2 fuel pumps and the fuel pressure gauge reads about 9 psi and the dial to adjust it doesn't seem to change the pressure. It almost seems that the plugs are fouling out as when I first had it, it had plenty of snap and now has a real dead spot. Is the proper fuel pressure to be about 4 psi?
Any suggestions? |
rhodyguy |
Nov 23 2007, 11:09 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
2.7 4 or 6? webers? what flavor? pumps in series or tandem? why 2 pumps? i'm confused. with idf series webers you want 3.5#, max. you can purchase self regulated pumps in dif gal per hour delivery rates. you might consider buying the weber book from cbperfomance. a set of fresh plugs will prob bring the snap back...for a while. read the carb tech writeups at www.aircooled.net and mark harney's site, www.carburetorclinic.com.
k |
Lo-Fi Version | Time is now: 8th June 2024 - 01:48 PM |
