Mallory 4060FI Fuel Pump, Will it work okay on 1972 D-jet? |
jjs3rd914 |
Nov 29 2007, 10:34 PM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Original Bosch 3 port pump starting to leak in the usual place around the connector. Made a few calls for a replacement. Review of past posts say to stay away from a rebuilt unit, cannot afford a new one for over $500. Also read that 75/76 pump will work, but they are not all that cheap. Besides the usual vendors have these on back order. We need a pump now. A past post recommended using a Mallory 4060FI. It actually has 3 ports, but are not sure if the "bleed port" is to be used per their diagram. Any comments? These pumps can be bought for $150. If they can be used what is the correct way to install. We already have relocated the pump to below the fuel tank by the steering rack. Car is a 72 with stock 1.7 with stock D-Jet.
Thanks jjs3rd914 |
toon1 |
Nov 29 2007, 11:36 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Original Bosch 3 port pump starting to leak in the usual place around the connector. Made a few calls for a replacement. Review of past posts say to stay away from a rebuilt unit, cannot afford a new one for over $500. Also read that 75/76 pump will work, but they are not all that cheap. Besides the usual vendors have these on back order. We need a pump now. A past post recommended using a Mallory 4060FI. It actually has 3 ports, but are not sure if the "bleed port" is to be used per their diagram. Any comments? These pumps can be bought for $150. If they can be used what is the correct way to install. We already have relocated the pump to below the fuel tank by the steering rack. Car is a 72 with stock 1.7 with stock D-Jet. Thanks jjs3rd914 That pump should work fine. |
Lo-Fi Version | Time is now: 5th June 2024 - 08:57 AM |
