Bus CV question, 914 axle conversion related :) |
Mueller |
Nov 30 2007, 12:28 AM
Does anyone know if this ridge actually does anything when used on Bus applications, it has a pretty heavy radius inside so it would seem kinda useless as a locating feature.
thanks !!! |
Cap'n Krusty |
Nov 30 2007, 12:46 AM
Howya doin', Mike!? Typically, that cutout is used for an internal gasket, one that rides half inside the bolt pattern. Later 911s have them, as do some later VWs. BTW, that doesn't look like a Bus CV joint. I don't have one here, so I can't be sure.
The Cap'n |
rick 918-S |
Nov 30 2007, 08:02 AM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Hi Mike!
Mueller |
Nov 30 2007, 11:24 AM
Howya doin', Mike!? Typically, that cutout is used for an internal gasket, one that rides half inside the bolt pattern. Later 911s have them, as do some later VWs. BTW, that doesn't look like a Bus CV joint. I don't have one here, so I can't be sure. The Cap'n Thanks John, I thought about the gasket after I posted (IMG:style_emoticons/default/smile.gif) I'll do some searching to see if I can see what other variations of bus CV I can find. By they way, I'm doing pretty good, the twins are doing great, walking/running like mad, starting to talk...starting to repeat (not good when daddy drops something and says oh S@#$ !!!!!! (IMG:style_emoticons/default/smile.gif) ) Hey Rick, how'z it going ??? |
Cap'n Krusty |
Nov 30 2007, 12:28 PM
Glad to hear all is well with you and your family! I just looked at a Bus/Vanagon CV joint, and I was right. That's not a Bus/Vanagon CV joint. They're flat on both faces. What you have is something else. The Cap'n
McMark |
Nov 30 2007, 03:38 PM
The 944 CVs we used on Andy's car looked like that.
0396 |
Nov 30 2007, 06:13 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Does anyone know if this ridge actually does anything when used on Bus applications, it has a pretty heavy radius inside so it would seem kinda useless as a locating feature. thanks !!! Mike, Long time no talk, I sent you an pm a while back to see how your doing. By the wa your posting, your doing just fine. Are you getting back into the game / hobby again? The car is now finished.. i;ve taken to W/S and B/W A few times now.. losts of fun. My 03 is still sitting.. having fun with the 914. The last time a took it out for a long ride was the time i gave you an ride in it (IMG:style_emoticons/default/sad.gif) All the best |
Lo-Fi Version | Time is now: 31st May 2024 - 07:51 PM |
