Engine Tin Joint Sealant? |
AvalonFal |
Dec 6 2007, 03:32 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Was there originally any type of sealant at the engine tin where the various pieces overlap and screw together? I removed the front left piece near the alternator and it looked like it had an old bead of sealant where it overlapped the next piece. Could've been done by a PO? Or original?
davep |
Dec 6 2007, 08:59 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
McMark |
Dec 6 2007, 09:24 PM
The majority of the motors I've looked at / taken apart have not had any sort of sealant. So by the numbers, I find it unlikely that there was anything there from the factory. The stuff that I have seen on a few engines is more of a foam strip than a 'goop'.
Pat Garvey |
Dec 6 2007, 09:37 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
The majority of the motors I've looked at / taken apart have not had any sort of sealant. So by the numbers, I find it unlikely that there was anything there from the factory. The stuff that I have seen on a few engines is more of a foam strip than a 'goop'. There IS a foam strip that was used on the sections that overlay the cooling box (or whatever it's called). Naturally, it disintegrates from age & it was very thin. It'll take some searching, but replaced mine with factory pieces in the late 70's & kept the parts labels. That's the only area that had it. All other pieces simply mated painted metal on painted metal. Pat |
davep |
Dec 7 2007, 07:22 AM
Now that I think about it, you are probably correct about it being a sponge tape. That is probably why they corrode so badly; foam retains water.
Pat Garvey |
Dec 7 2007, 07:35 PM
Now that I think about it, you are probably correct about it being a sponge tape. That is probably why they corrode so badly; foam retains water. Yeppir! But when it's young & not subjected to too much moisture it does its job - cooling! Sponge tape isn't really correct - it was just a length of sponge-type material (maybe still is), without adhesive on one side. I suspect it was jammed in as the pieces were torqued down. At least that's what I did with mine (no adhesive). You can easily reproduced this at any hardware store, though it will probably have adhesive on one side. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:03 PM |
