QUOTE(davep @ Dec 7 2007, 08:22 AM)
Now that I think about it, you are probably correct about it being a sponge tape. That is probably why they corrode so badly; foam retains water.
Yeppir!
But when it's young & not subjected to too much moisture it does its job - cooling!
Sponge tape isn't really correct - it was just a length of sponge-type material (maybe still is), without adhesive on one side. I suspect it was jammed in as the pieces were torqued down. At least that's what I did with mine (no adhesive). You can easily reproduced this at any hardware store, though it will probably have adhesive on one side.
