914/6 conversion-clutch,pressure plate,throwout bearing question |
rfuerst911sc |
Dec 20 2007, 06:15 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
At some point in time I will be ready to mate my 901 tranny to my 911 3.0 engine. I will be useing the 3.0 flywheel and I have already purchased the correct ring gear for the conversion. But my question is what pressure plate,clutch disc and throwout bearing to purchase? Some guys are saying you just use OEM 914/914-6/early 911 ( 71 and earlier ) is that correct? I know Kennedy,Patrick and others make hi-po parts but I'm useing a stock engine with carbs and headers so it's not a fire breathing beast (IMG:style_emoticons/default/biggrin.gif) The tranny is a side shifter if that matters. Part numbers would be appreciated if possible (IMG:style_emoticons/default/beerchug.gif)
IronHillRestorations |
Dec 20 2007, 07:06 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've only purchased/sold the package (custom ring gear, 225mm pressure plate & clutch disc, and a custom TOB), which is a Kennedy package, something like $650 or $750 for the package.
What ring gear do you have? If it's a stock 3.0 ring gear, it's not the right one for what you are doing. |
PRS914-6 |
Dec 20 2007, 10:13 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
If the car is going to be for street, I would avoid any pressure plate that is stronger than you need to get the job done. It gives you a heavy pedal for no good reason. Call Brett at Kennedy Engineering and he can tell you what the torque rating is for all the pressure plates.
Lo-Fi Version | Time is now: 9th June 2024 - 07:21 PM |
