At some point in time I will be ready to mate my 901 tranny to my 911 3.0 engine. I will be useing the 3.0 flywheel and I have already purchased the correct ring gear for the conversion. But my question is what pressure plate,clutch disc and throwout bearing to purchase? Some guys are saying you just use OEM 914/914-6/early 911 ( 71 and earlier ) is that correct? I know Kennedy,Patrick and others make hi-po parts but I'm useing a stock engine with carbs and headers so it's not a fire breathing beast
The tranny is a side shifter if that matters. Part numbers would be appreciated if possible
