1975 914 1.8L Engine Number Location |
jesiv |
Dec 22 2007, 08:46 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I don't see the engine number for my 1.8 (in the rear in theory the same location as the 1.7). Where is the engine number location for a 1975 1.8. A picture is worth a thousand words.
Thanks for the help! James |
JeffBowlsby |
Dec 22 2007, 08:54 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
JeffBowlsby |
Dec 22 2007, 08:56 PM
Well, similar but not the same. (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
jesiv |
Dec 22 2007, 09:31 PM
I believe i looked there. The engine number is not present.
Cevan |
Dec 23 2007, 09:10 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Here is my '75 1.8
jesiv |
Dec 23 2007, 01:19 PM
Here is a picture of that area. I have checed up by the oil filter for 2.0 location. The car has l-jet which I am working on e.g. intake removed and I have every reason to believe it is a 1975 1.8L CA motor. However, Is there a any other location for the engine number?
Attached image(s) |
JeffBowlsby |
Dec 23 2007, 03:02 PM
Looks like yu are in the right location for a 1.8
Maybe it was a replacement case? |
jesiv |
Dec 23 2007, 11:44 PM
Replacement case -- Does that mean I can name my own engine? As it currently does not have any uniquely identifiable identification. Sounds like fun.
Seems like the only why you get one of these is to order half the case. Which implies bad things happend to the original half...? Can anyone think of some other logical reason why no engine number is present or is in some unknown alternative location? |
JeffBowlsby |
Dec 24 2007, 12:37 AM
You sure its not a 2.0L case?
I don't know anything about how 914 cases were available as replacements, hopefully someone with experience will chime in. I had a T3 VW at one time where I pushed a rod through the case and the whole case was replaced for something like $35. back in the late 70s. I assume that 914 cases were available like that and I doubt they had a SN, but do not know. Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:45 AM |
