| KaptKaos |
Jan 1 2008, 10:33 PM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
The ignition switch on my 76 seems to be sticking when I try and start the car. To get the starter to stop, I have to switch it off and on again.
I took off the wheel. As I was taking off the wiper and turn signal switches, I noticed that they seemed different. Did they change these from earlier cars? I think my 73s are different. Anyone know? TIA. |
| SLITS |
Jan 2 2008, 11:55 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
There are 3 different styles:
Early- '70 - Mid 72? Median- Late '72 to '74 Late - '75 & '76 The late ones are about $5 at Pelican To get to it ... there are 5 allen head bolts on the steering columun (bottom) ... 4 hold the assembly to the dash frame. There is one single that mounts the turn signal/washer assembly to the steering housing. Pull the steering wheel. Pull a "C" shaped clip off the steering shaft. It's soft and will bend (remember to put it back when reassembling). Take out the single allen head fastner on the steering column. The entire assembly will now slide off the shaft with a little coaxing. The wires / washer feed tubes are long enough to pull it without disconnecting the harness or disassebly of the wiper/washer/ turn signal / headlight switch. Once the assembly is off you will see the small screw that hold the plastic portion of the ignition switch in. Pull the connector, pull the switch and replace. I took one completely apart like you do the Median assembly only to find the above out ... what a PITA. |
| Sleepin |
Jan 2 2008, 08:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I will be tackling mine this weekend! (IMG:style_emoticons/default/barf.gif)
| tod914 |
Jan 3 2008, 12:14 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
"And Bruce Patterson makes another interesting point:
What I've found out since there was only 4100 76's made they're a little different than the rest. To retract the metal steering surround that holds the ignition switch (there is no screws holding it) you insert the key like you are going to remove the tumbler,turning the key unlocks the tab thats holding it on the steering shaft,letting you pull the whole piece off, exposing the switch and the set screw for easy removal and replacement.If you dont turn the key there's no way that assembly will come off the shaft.You may want to include this info on to the tech article. Thanks Bruce Patterson" courtesy from the bird |
| SLITS |
Jan 3 2008, 11:59 AM
"And Bruce Patterson makes another interesting point: What I've found out since there was only 4100 76's made they're a little different than the rest. To retract the metal steering surround that holds the ignition switch (there is no screws holding it) you insert the key like you are going to remove the tumbler,turning the key unlocks the tab thats holding it on the steering shaft,letting you pull the whole piece off, exposing the switch and the set screw for easy removal and replacement.If you dont turn the key there's no way that assembly will come off the shaft.You may want to include this info on to the tech article. Thanks Bruce Patterson" courtesy from the bird Ok, Insert before removing allen head fastner .... "Disconnect negative cable from battery" Insert after removing allen head fastner .... "Insert key and turn tumbler to "On" " And he should have called it a "locking pawl", not a tab (IMG:style_emoticons/default/biggrin.gif) Tech article now complete (IMG:style_emoticons/default/shades.gif) The surround is plastic (one piece) and will slide off to the rear of the assembly if you want to expose the guts .... |
| Sleepin |
Jan 3 2008, 11:29 PM
I dig the avatar Ron!
Lo-Fi Version | Time is now: 2nd April 2026 - 02:54 PM |
