carb fuel pump placement, thoughts? |
slackin' at work |
Jan 3 2008, 10:33 AM
i should be working Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
OK, my car is currently dual carb'd and is running a Facet fuel pump up-front
under the tank. Im eventually going to go back to FI but in the meantime I want to replace the plastic fuel lines (with tangerine's stainless), replace the front rubber lines, and add a front swaybar (sorry CW people). I only want to take the hood and tank off once. I want to enjoy my car as-is this spring. meaning I probably won't do the conversion back to FI until summer. So with that said, I want to run a rotory-style pump (from CB Performance) so I can ditch the Facet. And finally my question... do you think this pump will work behind the lines close to where the original pump will go. I know they say under the tank because those pumps are pushers and not pullers... but if you think about it, with our front mounted tank there shouldn't be any issues. thoughts? |
ruddyboys |
Jan 3 2008, 10:59 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I replaced the Facet pump 3 years ago with the CB performance rotary, it is in the same position as the original FI pump, and have had no problems. The reason they put the fuel pump up front I believe was to stop vapor lock.
boxstr |
Jan 3 2008, 11:27 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
I run a Mallory rotary pump, for a SBC V8 with holley 4 barrel carb., in the front trunk because they pushers and not pullers.
CCL |
rhodyguy |
Jan 3 2008, 11:53 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
keeping the pump lower than the supply outlet on the tank, you should have no problem with the cb pump. you just want to avoid making the pump pull the fuel uphill.
k |
SirAndy |
Jan 3 2008, 01:57 PM
Resident German Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i had the CB rotary in the stock location in the back, never had any problems with it ...
(IMG:style_emoticons/default/bye1.gif) Andy |
Joe Owensby |
Jan 3 2008, 08:09 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I just mounted a CB pump below the tank, on the driver's side below the sway bar. This is about the same location as the pump on newer 914's. I used this in conjunction with Chris' SST lines. I am running carbs now, so I only used one line, but I have both SST lines through the tunnel, as I plan to go to a newer version of fuel injection sometime soon, maybe the one Jake sells. By the way, if you go to FI, then I don't think the CB pump will work, as it is only about 3 1/2 PSI. I am thinking that if I later go to FI, I will need a new high pressure pump. JoeO
slackin' at work |
Jan 3 2008, 09:46 PM
thanks for the replies guys.
joe, I wasn't planning on running the cb pump with the fuel injection... just moving it to the back until I switch it all back to stock FI. that way I only have to mess with the gas tank and front lines once. (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 01:45 PM |
