I have a oil pressure sender installed finally., Now how do I wire it? |
Dr. Roger |
Jan 8 2008, 04:01 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
How do I wire it?
Are there already pre-existing wires in the harness in the engine bay that I hook to either the on/off or the variable terminals on the pressure switch? I've always had a red light on in my dash. I"m guessing that is the oil pressure dummy light. But the Renegade switch has two terminals on it... Now I'm confused.. and getting frustrated. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/chair.gif) I need a hug... LOL (IMG:style_emoticons/default/grouphug.gif) My car is a '74 if that makes a difference. |
type47 |
Jan 8 2008, 08:14 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
there should be a wire in the harness for the oil pressure switch. i looked in a wiring diagram for a 74 (i think you can see a wiring diagram on pelican) and it shows a green/red wire for the oil pressure switch. (track 70 to F1, oil pressure switch). if your renegade switch is a dual pole, use one pole (you have to find the correct one) for the idiot light and you will have to run a wire for the other pole to a gauge.
thesey914 |
Jan 8 2008, 08:41 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
The Red/green wire goes to the pressure switch. There should be a green/black wire that is used for temp that you could use for a pressure gauge.
I ran a new green/white wire that I used for my pressure gauge (as in the 911 loom) so I could run a pressure switch, a pressure gauge an temp gauge. |
McMark |
Jan 8 2008, 09:44 AM
(IMG:style_emoticons/default/agree.gif) These guys have got you on the right track.
SirAndy |
Jan 8 2008, 05:19 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
But the Renegade switch has two terminals on it... one for the pressure gauge, one for the idiot light ... the wire for the idiot light is already in your harness, it's green/red. you'll have to run a wire for the pressure gauge or use a unused wire in your harness ... (IMG:style_emoticons/default/bye1.gif) Andy |
Dr. Roger |
Jan 9 2008, 04:22 PM
Lo-Fi Version | Time is now: 9th June 2024 - 12:02 AM |
