Total noob question, transmission removal |
stepuptotheMike |
Jan 12 2008, 02:52 PM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
So I'm trying to get the engine and trans split apart. I've got all 4 bolts off, the starter is gone. I've broken it loose to the tune of about 4 or 5 mm seemingly all the way around.... but this damn thing just doesn't want to come apart.
Is there some magic trick that I'm missing here? I've tried raising/lowering the trans on my jack thinking that maybe I'm just off on the angle a bit. Still no dice. (IMG:style_emoticons/default/headbang.gif) Any thoughts or suggestions would be appreciated. Regards, Mike |
type47 |
Jan 12 2008, 03:07 PM
i think only 4 bolts holds them together. my only thought is to make the engine and tranny align so there is no binding on the input shaft and the flywheel/pressure plate.
Dr. Roger |
Jan 12 2008, 03:13 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
i've never experienced thi sbut is it possible the clutch plate could be stuck to the spline on the transaxle input shaft?
Has it been sitting a while? |
stepuptotheMike |
Jan 12 2008, 03:20 PM
benalishhero |
Jan 12 2008, 03:29 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
sounds like tranny spline is stuck to the driven plate
stepuptotheMike |
Jan 12 2008, 05:35 PM
Finally..... success. The POS came apart. Ended up having to pry it apart with wood block. This tranny case has been welded up a couple of times. 1 at the bell housing and then once at the rear mount.
Next step.... pull it apart and see what it looks like on the inside. -Mike |
Lo-Fi Version | Time is now: 8th June 2024 - 03:12 PM |
