Dip stick tube, How do you get that thing out? |
trojanhorsepower |
Jan 7 2004, 06:47 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Any tips? I need to err, straighten mine. Is it just a press fit?
Thanks again -Pete |
trojanhorsepower |
Jan 8 2004, 05:43 PM
Bump.
Gint |
Jan 8 2004, 06:16 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Most dip sticks are press fit. I never pulled one out of a 914 TypeIV though. Did you try pulling straight up on it?
Aaron Cox |
Jan 8 2004, 06:25 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
if you pull one...pull an extra one for me! mine was broken 3 inches from the top....i now have a shortened dipstick (IMG:style_emoticons/default/rolleyes.gif)
they are NLA for sure |
trojanhorsepower |
Jan 8 2004, 06:45 PM
Humm,
Maybe I should just leave it alone? I would think that it could be pressed out from inside, but I am not about to take this thing apart again just for that !! I tried to pull it gently from the top with no success. Thanks all for the info. -Pete |
Aaron Cox |
Jan 8 2004, 06:53 PM
pet shows the dipstick, but the tube is part of the case to them (IMG:style_emoticons/default/confused24.gif)
hargray2 |
Jan 8 2004, 08:00 PM
fuh-q Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
better leave it alone. Isn't the tube brass?
trojanhorsepower |
Jan 9 2004, 07:58 AM
Could be brass, but I thought it was copper. Brass would make more sence, I recon.
Any body ever take one out? -Pete |
JWest |
Jan 9 2004, 08:08 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
The tube is steel, and it's a press fit. They were not intended to ever come out. If you really need it out, I would suggest heat in the area and some type of tool to pull (more than arm strength), but be prepared for it to break (prabably right at the case interface!) and to have to drill it out. Then you will have to create a new one most likely as they are not an available item AFAIK.
It would be worth checking to see if you can see it through the taco plate hole, in which case you might be able to drift it out. |
adam912 |
Jan 9 2004, 02:19 PM
Newbie Group: Members Posts: 17 Joined: 28-August 03 From: Ashland, OR Member No.: 1,084 |
I have a case with no tube in it and my old case with a tube that will not come out! I discovered that the tube is the same material and size as stock hard (steel) fuel line. So if you have a piece in the junk box ( I had a piece from my old 912 motor) straighten it out, cut to length and you're there!
Adam |
Lo-Fi Version | Time is now: 1st June 2024 - 06:07 PM |
