Emergency Brake on 911 Suspension |
Britain Smith |
Jan 8 2004, 01:01 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Does anyone here have any experience disconnecting the emergency brake from the hub on a 911 rear brakes? How do you do this?
-Britain |
JWest |
Jan 8 2004, 01:05 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Which part of it do mean?
If you mean the whole assembly, then you pull the hub and take out the four bolts that hold the bearing in. The e-brake plate is held on by those bolts. |
Britain Smith |
Jan 8 2004, 01:48 PM
I just want to seperate the rear trailing arms from the car and the only thing holding them on at the moment is the emergency brake. Do I have to remove the hub to disconnect the brake or is there an easier way?
-Britain |
JWest |
Jan 8 2004, 02:08 PM
Oh, the cable. It has a nut screwed on the cable, but I think there is a cotter pin (not sure about all years). To get the cotter pin out you will have to pull the brake disc for access.
It's probably easier to undo the cable at the handle and pull it with the arms. |
Jeroen |
Jan 8 2004, 05:35 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Did you take the disk off already?
Should be pretty self expanatory once you have the disk off... There's a little castled nut (with a split pin) on the cable. Remove it an you can pull the cable out cheers, Jeroen |
Eric_Shea |
Jan 11 2004, 01:06 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) Like he said if you haven't dug in yet...
Lo-Fi Version | Time is now: 4th June 2024 - 10:47 AM |
