Need help with 911 brakes |
ahdoman |
Feb 8 2008, 11:00 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I got these from a buy to upgrade to 5 lug. Just a couple of questions...
1) What type are these? (Need to know so I can order rebuild kit) 2) After I take out the 4 cross bolts should they just split? 3) How do I get this piston out? The compressor trick worked fine on the other one. |
Eric_Shea |
Feb 8 2008, 11:40 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
1. Those are A-Calipers - 3.5" Mounting ears and fluid inlet at the bottom. Thinner spacers are for the 911SC (thicker would be for the Carrera)
2. Yes. You will "need" a Ribe bit set to do it though. Those have an extremely small R6 head which I feel is disproportionate to the M9 hardware (14mm nuts). Use generous amounts of heat (read: MAPP torch) and a fairly sizable air wrench. ***ONLY USE THE RIBE BIT TO HOLD THE FASTENER.*** Use the 14mm socket and wrench to do the turning. NOTE: Depending upon "who" you order your rebuild kits from... they may not have the caliper 1/2 seals so you can put them back together. (IMG:style_emoticons/default/whistle[1].gif) 3. First you will need to block off the other bore. Lowe's has a decent selection of large rubber washers. Get one that's larger than 48mm. Cut some flat stock and then use a c-clamp or two to cap the bore. If it won't come out with air you will need to use grease. Get an el cheapo Harbor Freight gun and unscrew the tip. The thread pattern will be an exact match for the fluid inlet. Screw it in and pump it out with the grease. You have air tools right? (or you can buy these for $249.00) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 31st October 2024 - 05:42 PM |
