| 914pipe |
Feb 14 2008, 09:24 PM
Say......TEEEEEEEN!!!!! ![]() ![]() Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Hi there:
There was a guy running hard pipes of 3/4" ID.... I use to have a link but doesn't work. Does anyone knows if that configuration ever worked...? Would like to hear from that guy.... I have the opportunity to get 3/4 in ID SS braided hoses.... Thanks..!!! Pics...? |
| wbergtho |
Feb 14 2008, 09:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
I have heard of people using 3/4 id hoses...and I've heard of people using copper (don't like) but it seems a wee bit small. I use 1" and 1 1/4" Gates Green stripe hoses through the heater ducts in the longitudinals. No hoses hanging under the car waiting to be wiped out on a speed bump. It takes a bit of effort to snake the lines through and to fabricate cut outs through the forward longs and forward firewalls...but if done correctly, you'll have a clean install and two continuous hoses from the engine to the radiator. More importantly, you can route the hoses in such a way that there are absolutely no sharp 90 degree bends to disrupt flow. Call Rod Simpson. He believes in the small diameter method.
Bill |
| Andyrew |
Feb 14 2008, 10:06 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I believe that was Rick w/ the Alien..
I would go with what bill uses above.. or just 1", thats what rennegade recommends.. IIRC |
| 914pipe |
Feb 14 2008, 10:07 PM
Thanks Bill.... any pics from your set up...??
Thanks |
| marks914 |
Feb 15 2008, 08:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Desert hybrids uses 3/4 black (1 in od) pipe under the car. seems to work fine in arizona.
I have been running 1in copper/aluminum lines under my car for 40,000 miles and 6 years, no problem. I don't understand why copper gets the bad rap. Solder melts at 450F, and the better radiators are made from copper because of copper's superior heat transfer. I could see if you are worried about denting it running something over, but why don't ypu watch where you are going. if you hit your floor pan on something, you probably will hit your engine bar too. Mark |
| ajracer |
Feb 15 2008, 10:10 PM
Member ![]() ![]() Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
nukepipe:
Not sure which hard line installation you previously saw, but here is a couple of photos of my installation from a couple years ago. Thick wall aluminum tubing 1" ID; must say it took two guys eight hours with and large commercial pipe bender to fabricate these up. Seem to work fine with no problems/concern (yet) with bottoming out. Trust this helps. Allan Attached thumbnail(s) |
| ajracer |
Feb 15 2008, 10:14 PM
Another shot
Attached thumbnail(s) Attached image(s)
| 914pipe |
Feb 15 2008, 11:39 PM
| vespasoul |
Feb 25 2008, 12:19 AM
Newbie ![]() Group: Members Posts: 10 Joined: 2-April 06 From: las vegas, nv Member No.: 5,809 |
Desert hybrids uses 3/4 black (1 in od) pipe under the car. seems to work fine in arizona. I have been running 1in copper/aluminum lines under my car for 40,000 miles and 6 years, no problem. I don't understand why copper gets the bad rap. yeah and with copper you can install a toilet in the front trunk too the question you should be asking yourself is: am i running cooling lines in an auto??? or running plumbing in a house??? |
| jd74914 |
Feb 25 2008, 12:38 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,891 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Water is water . . .
Lo-Fi Version | Time is now: 25th November 2026 - 06:12 PM |
