OK, so what do I do with these, 911 swingarms |
ahdoman |
Feb 18 2008, 07:11 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
One of my neighbors brought these over to me and left them in my yard. He says he thinks they are from an early 911. Is there anything of value on these? If so, what are they worth?
degreeoff |
Feb 18 2008, 07:33 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
They are worth the rear hubs (maybe?) and the Ebrake for a conversion....sell the hubs for $150 ish and the ebrake parts anothe $150...best case scenario.
My $.02 |
Cap'n Krusty |
His idea of "early" is skewed. Late 70s, 80s, something like that. I don't see enough 911s anymore to remember. Seems to me the hubs with the centering profile are pretty late. They're aluminum, which didn't arrive until 1974. Somebody's bound to have a use for them. The Cap'n
Eric_Shea |
Feb 18 2008, 07:41 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
A fair amount of early 911 guys want to switch from the steel to aluminum control arms. If you sell off the handbrake parts they'll be of less value to the potential buyer. Besides, those handbrake assemblies are for the larger bearings and require a bit of work to fit onto our cars. Easier for a handbrake guy to look at a slightly earlier set-up.
Offer them on the Pelican 911 board. One problem the potential 911 buyer may have is the rear shocks. The mounting geometry has changed from the early steel arms to these. The bolt on these is not only thinner but further back on the arm. The actual body of the 911 was changed in 74 to accomodate this, where the shock mount channels/tubes are angled to reflect the change in the control arm. Some Koni's may not fit and, the early Koni's (because of the bolt size) would for sure have to change. Again, offer them as is and sell on the Bird Board for $3-400 |
ahdoman |
Feb 18 2008, 07:44 PM
Thanks guys. So are these at least from a 74 and later 911?
PRS914-6 |
Feb 18 2008, 07:47 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
If there is a time that you want to convert to 5 lug you should keep them. A spacer is easily made for the wider bearing issue and the emergency brake can be adapted for use in a 914 with some fabrication.
If you have no intent in doing the above, Eric is right....list them on the bird board or e-Bay |
914Sixer |
Feb 18 2008, 08:19 PM
914 Guru Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Cap'n is correct they are later 911 because of the centering hub flange. 78-79 maybe later, I think they appeared with the 3.0 motor. Sell them complete.
PRS914-6 |
Feb 18 2008, 08:48 PM
For adapting the 5 lug axle flanges to a 914 Read This Thread
KaptKaos |
Feb 18 2008, 09:47 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Too bad those don't work on 914s. That would be a sweet upgrade.
smontanaro |
Feb 18 2008, 09:48 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
andys |
Feb 19 2008, 10:46 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Steve,
Bring 'em by my garage. I've got a set from an '89 Carrera that we can compare against. You shoulda mentioned something about them on Sat. Andys |
Eric_Shea |
Feb 19 2008, 11:29 AM
QUOTE If there is a time that you want to convert to 5 lug you should keep them. A spacer is easily made for the wider bearing issue and the emergency brake can be adapted for use in a 914 with some fabrication. I subscribe to a simple; "sell them complete and buy the right 68-73 rear hubs and handbrake assemblies with the money" theory. Or... mod a 914 hub. No machining of spacers needed. No fabricating of the wrong handbrake parts needed. Steve, keep in mind you'll be going down a very slippery (read: $$$) slope of 911 handbrakes and calipers etc. with a 911 hub. -6 stub Axles? 944 stub axles? CV's? Custom Axle Mods? Fabricating of handbrake systems? Cables? 911 rotors? Rear calipers? All good stuff BUT; be mindful of it as you approach the edge. |
Lo-Fi Version | Time is now: 15th June 2024 - 11:38 AM |
