Exhaust heat shield, weight... thoughts about removal? |
yarin |
Feb 20 2008, 07:13 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I saw someone on here getting rid of the exhaust heat shield that's fixed to the rear trunk for weight savings... does anyone know what it actually weights? Doesn't strike me as being remotely heavy. Secondly, is it necessary? My muffler sits right under this shield. Any thoughts?
Pat Garvey |
Feb 20 2008, 07:45 PM
I saw someone on here getting rid of the exhaust heat shield that's fixed to the rear trunk for weight savings... does anyone know what it actually weights? Doesn't strike me as being remotely heavy. Secondly, is it necessary? My muffler sits right under this shield. Any thoughts? I'd say it depends on your use of the car. You won't lose a whole lot of lbs by removing it, but if you're a hardcore DE, race or auto-xer, I'd consider it. But.... If you use your 914 for occasional trips - don't pack any liquor in the rear trunk! It gets hot back there without any additional help! You're probably looking at about 5 lbs reduction, but the car was engineered for that part in place. I'd leave it. Pat |
PeeGreen 914 |
Feb 20 2008, 10:20 PM
I would cut it out. It really doesn't do much but add weight. I had a thermostate in there just to see what would happen, and the temp didn't even change a whole degree from before and after. I think it was about 5lbs when I took it off. It is really just a pain when you need to do things near there. Removing it gives you that much more room.
yarin |
Feb 21 2008, 11:47 AM
I would cut it out. It really doesn't do much but add weight. I had a thermostate in there just to see what would happen, and the temp didn't even change a whole degree from before and after. I think it was about 5lbs when I took it off. It is really just a pain when you need to do things near there. Removing it gives you that much more room. Ok.. i didn't dig into it, but how do i go about removing the heat shield? are there spot welds to drill out? is it bolted in? I might add some exhaust heat shield fabric up there if i'm worried about heat. thanks |
toon1 |
Feb 21 2008, 12:09 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
It's held in there by 4 little L brakets.
With a sawsall or similar ,(IMG:style_emoticons/default/sawzall-smiley.gif)............ 5min. you'll lose 5 lbs! (IMG:style_emoticons/default/biggrin.gif) |
brer |
Feb 21 2008, 12:37 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
I like my heat sheild.
McMark |
Feb 21 2008, 01:01 PM
(IMG:style_emoticons/default/rolleyes.gif) Cutting just to cut? 5lbs is worth, what? 0.0005 seconds at an AX? Sheesh.
jhadler |
Feb 21 2008, 01:47 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
(IMG:style_emoticons/default/rolleyes.gif) Cutting just to cut? 5lbs is worth, what? 0.0005 seconds at an AX? Sheesh. It's cost-benefit. Just ask Brant, his 914 is ridiculously light, and it's still sporting all steel body panels. It costs next to nothing to loose the 5 lbs that are hanging out at the very rear of the car. the effective change in the overall weight of the car is minimal, but the effect on the polar moment of inertia of the car is more. edit - if the ONLY thing you're doing is loosing the heat shield, then it's kindof silly. But if it's part of an overall weight reduction plan, it's a good one. A no-brainer if you ask me... Couple o' spot welds, and it's gone. -Josh2 |
RoadGlue |
Feb 21 2008, 02:24 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) with jhadler on this one.
Elliot Cannon |
Feb 21 2008, 02:36 PM
If you're worried about heat in the rear trunk. Spray the underside of the trunk with VHT high temp spray paint. It acts as an insulator.
Cheers, Elliot |
burton73 |
Feb 21 2008, 04:40 PM
burton73 Group: Members Posts: 3,549 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Hot news: My 914-6 did not have one on so George sent me one to put on. A 1970 unit with brackets is 3.5 Lb on the scale with no paint on it. So you guys really do not need to get that high on the big weight loss.
If the factory had one, there must of been a good reason and that is why I am putting one back in. Bob |
McMark |
Feb 21 2008, 04:43 PM
(IMG:style_emoticons/default/agree.gif) FOR A RACECAR (IMG:style_emoticons/default/cool.gif) I don't see the point of cutting a street car for no reason. |
RoadGlue |
Feb 21 2008, 04:45 PM
Brando |
Feb 21 2008, 05:38 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
It's there for a reason... so your groceries in the trunk don't melt or cook at the furthest back. When sitting in stop-and-go traffic the trunk gets really hot.
Rick_Eberle |
Feb 22 2008, 06:26 AM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
(IMG:style_emoticons/default/agree.gif) FOR A RACECAR (IMG:style_emoticons/default/cool.gif) I don't see the point of cutting a street car for no reason. (IMG:style_emoticons/default/agree.gif) If you're THAT worried about a couple of pounds, maybe it's time to cut down on the burritos... (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/happy11.gif) |
Spoke |
Feb 22 2008, 06:33 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I have the one off on my green 914. With Bursch muffler, I haven't noticed that much heat buildup in the trunk. Definitely don't want to bring home chocolate or something or something that will melt in the trunk anyway.
My shield weights much less than 3.5LB because I had it chemically thinned by road salt and debris over a 30+ year period. |
yarin |
Feb 22 2008, 09:08 AM
Yes I consider my car a racecar. I rarely drive it on the street, usually tow it to events. The car is lightened; no interior, no trunk/engine hatch springs, no heating parts left, light wheels, etc. I could also use a but more room back there for a new muffler which ironically weighs more than the old one. (IMG:style_emoticons/default/mad.gif) Car was too loud before though. I'll post pics when its all done.
Thanks! |
Lo-Fi Version | Time is now: 8th June 2024 - 03:17 PM |
