| cwpeden |
Feb 21 2008, 06:59 PM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
The topic says it all...I just sick and tired of replacing hard o-rings
I'm not opposed to silicone, but what kind, where and how much? Pics would help... Thanks in advance |
| McMark |
Feb 21 2008, 07:01 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Get viton, use Loctite 565 on them.
| Cap'n Krusty |
Feb 21 2008, 07:41 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Get viton, and use motor oil on 'em. I have a motor apart here right now with over 100K miles and 12 years on the seals, and they're still working fine. The Cap'n
| cwpeden |
Feb 21 2008, 08:26 PM
See, i dont understand this... Every year I replace the seals and the ones I get are said to be Viton. The supplier is very reliable. Yet they come out in pieces or break coming off the tube.
No problem with the motor oil though, they are always soaked in it. The problem is they are soaked on both sides! (IMG:style_emoticons/default/rolleyes.gif) |
| McMark |
Feb 21 2008, 09:13 PM
Heat damage? Got an oil temp sensor in there? Cylinder heat temp?
| cwpeden |
Feb 22 2008, 01:43 AM
Nope no heat problems....I'll get new ones and try the PST
| Dave_Darling |
Feb 22 2008, 02:09 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Make sure there are no sharp edges in the bores they ride in.
Make sure the bent wire retainer is seated on the shoulders of the tubes. If they're coming out cracked or hardened after a few months, they probably aren't Viton... Viton is very heat resistant, and deals with oil just fine. Most of the Viton PR seals I've seen were brown in color; if yours are red or green they are likely OEM silicone, if black they may be silicone or Viton. --DD |
| cwpeden |
Feb 22 2008, 02:10 AM
Yup, they were red.
| purple |
Feb 22 2008, 07:50 AM
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I have vitons all around and my passenger side is just a pain in the ass.
i'll replace both seals on a tube, and it'll go from leaking at the head, to leaking at the case. friggen annoying. I'm about to put some gasket maker around the things right as i put them in. that would entail dropping the engine NO WANT! I had a similar thread to this and mr. Jake Raby was saying vitons are shit and get stuck as you put them in or bunch up. he says to use silicones. just my two cents |
| Jake Raby |
Feb 22 2008, 10:32 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I never said they were "shit".. All I said was they are NOT a magical remedy to leaks and will not make up for losuy preparation and install procedures.
They are more difficult to install and are just as prone to install damage due to that. Better materials won't trump proper install and preparation. |
| SGB |
Feb 22 2008, 10:43 AM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Mine leak like a bad diaper because when "professionals" replaced mine, they gouged the cylinder head bores in a couple of locations. Without welding, mine are just gonna leak. After awhile, that smell is kinda reassuring...
Lo-Fi Version | Time is now: 2nd May 2026 - 04:21 AM |
