> Tilton Floor Mount Pedals
kyhunting
post Feb 25 2008, 05:05 PM
Has anyone used the Tilton Floor Mount Pedals? If so do you have pictures?
Replies(1 - 19)
jd74914
post Feb 25 2008, 10:30 PM
Its alive
This question should be in the garage. It would get more views there, but here is a picture of a cars with it. (IMG:style_emoticons/default/smile.gif)
post Mar 5 2008, 06:45 PM
Resident German
QUOTE(jd74914 @ Feb 25 2008, 08:30 PM) *
dakotaewing
post Mar 5 2008, 08:54 PM
fagafsbg
dakotaewing
post Mar 5 2008, 08:59 PM
Right Hand Drive
LarryR
post Mar 5 2008, 09:20 PM
QUOTE(dakotaewing @ Mar 5 2008, 06:54 PM) *
fagafsbg
SWEET! I hate to ask how much do a set of those cost?
dakotaewing
post Mar 5 2008, 11:33 PM
$468 at Summit
dakotaewing
post Mar 5 2008, 11:35 PM
$2169 at HRP.com
sww914
post Mar 5 2008, 11:42 PM
They're really cool. When I build a 914 for my son who's a dwarf in a couple more years, I'll use those and move them back towards the seat so that his short little legs can reach the pedals.
Nobody will be able to steal the car with their knees stuck into their chin.
tdgray
post Mar 6 2008, 03:26 PM
QUOTE(sww914 @ Mar 6 2008, 12:42 AM) *
Now that is a funny visual (IMG:style_emoticons/default/av-943.gif) ... not your Son... the thief (IMG:style_emoticons/default/biggrin.gif)
sww914
post Mar 6 2008, 04:25 PM
Oh, my son's funny too! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
byndbad914
post Mar 6 2008, 08:47 PM
shoehorn and some butter - it fits
QUOTE(dakotaewing @ Mar 5 2008, 10:33 PM) *
$468 at Summit
with master cyls an all I had about $800 in mine getting it in the car and working. Worth every penny to go to dual master, adj bias and a slave on the clutch.
charliew
post Mar 7 2008, 10:29 AM
QUOTE(dakotaewing @ Mar 5 2008, 08:54 PM) *
fagafsbg
Hey Thom, Thats a nice pedal fitup, looks like a lotta work and expense. I'm in Crawford planning a 914 subie. Got most of the parts. Gonna be a street car. I like the dual master brake setup with the balance bar and clutch master. Hoping for 18x8 and 18x11 with steel flares. May down size before the real construction starts. 9's are really big enough. At best i'tl never see more than 350 whl hp. Gotta get rid of a lotta junk before I can start the 914. Looking forward to milder weather. Post some pictures as you go. The pedals are really high tech.
Charliew
PeeGreen 914
post Mar 7 2008, 01:00 PM
So how would you do a plantation kit on a 901? Can you even put a slave on a 901?
byndbad914
post Mar 7 2008, 05:20 PM
QUOTE(Phoenix 914-6GT @ Mar 7 2008, 12:00 PM) *
I have a 930 so it is a bit different, but I have seen them on a 901. Just gotta make a bracket to bolt it to the trans and then adapt the end of the clutch fork. Trust me, that will be the easiest part of the whole thing, so if that seems hard to figure out, then the pedal assy will be a nightmare (IMG:style_emoticons/default/smile.gif) I didn't find any part of it difficult at all if that is encouraging..... just tedious.
PeeGreen 914
post Mar 7 2008, 05:32 PM
Now you have me thinking I should give this a try. What did you use for a slave? What was it off of?
Do you have any pictures of your work?
dakotaewing
post Mar 8 2008, 12:18 AM
QUOTE(charliew @ Mar 7 2008, 10:29 AM) *
fagafsbg
Charliew
Not my setup Charlie - Just pics in my collection from over the years... (IMG:style_emoticons/default/biggrin.gif)
byndbad914
post Mar 9 2008, 12:16 PM
QUOTE(Phoenix 914-6GT @ Mar 7 2008, 04:32 PM) *
sorry for the late response... was loading the trailer F and racing yesterday. I had the assembly in the "old" configuration (when it was still a full stock tub) and have a couple pix that show what it looked like but nothing with great detail. I made an aluminum plate to "flatten" the floor (the pedal box area "sinks" down), made some spacers to fit in the sunken area to support the plate and bolted it down. Now the floor was essentially flat. Then I mounted the pedal assembly to my alum plate with the short master cyls right against the firewall. The slave cyl I used was a standard Wilwood brand slave unit and it is still working in the car just fine as of yesterday.
Here are my old pics
you can see I had rigged up a brake light switch with the original switch just to get the car legal again. Shortly after this pic I added an inline pressure switch to operate the brake lights (you can get them from Summit... IIRC mine is a Painless Wiring brand)
The slave - I bent the rod end immediately cuz I have a Kennedy clutch setup for the V8 that is fricken brutal so I simply used an angle-iron steel bracket in place of the setup you see here and it worked perfectly. I machined up a piece of box steel to slip-fit over the old 930 bracket and had it professionally welded
retrofit
post Mar 9 2008, 12:34 PM
fagafsbg
(IMG:style_emoticons/default/piratenanner.gif) This is awesome. Great for anyone 5'-6" or so who doesn't like the look of always having your seat halfway up towards the dash. One way to justify the expense-just in case you have to-would be to avoid a pedal set rebuild buy this new setup instead. Hmmmmm.
PeeGreen 914
post Mar 9 2008, 02:08 PM
QUOTE(byndbad914 @ Mar 9 2008, 11:16 AM) *
So if I were to ask you everything I would need to order to do this do you happen to have a list of al the parts needed? I thank you for all the time you've taken already. This could be great for completing my race car.
Oh, how is the throttle handled?
- Lo-Fi Version Time is now: 9th June 2026 - 02:08 AM
