Wire size, Battery to starter |
spunone |
Mar 3 2008, 08:30 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
What size wire should be used to go from Battery to Starter?Thanks
Dr. Roger |
Mar 3 2008, 10:06 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
spunone |
Mar 3 2008, 10:07 AM
(IMG:style_emoticons/default/icon_bump.gif) somebody gots to know
Borderline |
Mar 3 2008, 10:08 AM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
I don't know the size, but in the past I have bought welding cable from a welding supply to make my own battery cables. worked good. The better the cable the better the engine will spin over. (IMG:style_emoticons/default/biggrin.gif)
spunone |
Mar 3 2008, 10:09 AM
High torque Starter 2.0 motor battery location in rear trunk
Joe Bob |
Mar 3 2008, 10:52 AM
Big is GUD.....I use 0 gauge on my hand built Speedster and the 6volt 356 I just re did. They were BOTH getting hot when cranking using the kit supplied cables.
The electric cars guys use welding cable and then crimp there own lugs and connectors. There is a special tool that cuts cable like butter. Just don't use on anything else....destroys the tool. |
spunone |
Mar 3 2008, 11:21 AM
Thanks Z going Big maybe #1
Spoke |
Mar 3 2008, 11:27 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I've used either 2-gauge or 4-gauge from my FLAPS.
Matt Meyer |
Mar 3 2008, 11:36 AM
Überlurker Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest |
Never used him and I am not affiliated but I think I will buy my next set from this guy. Custom Battery Cables
His connections look top notch. He doesn't offer a black cable with a red stripe though. His thoughts on battery cable size: What size cable do you need? |
Joe Bob |
Mar 3 2008, 11:43 AM
I think 0/2/4 are the sizes.....
Dr. Roger |
Mar 4 2008, 02:25 AM
Hey Paul,
Another thing to consider is strand count. The more strands, the more pliable, and longer life it will live. I'd go larger than 0 IMHO. .32" diameter seems a little small for a couple hundred Amps, doesn't it? =-O |
jk76.914 |
Mar 4 2008, 05:38 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Hey Paul, Another thing to consider is strand count. The more strands, the more pliable, and longer life it will live. I'd go larger than 0 IMHO. .32" diameter seems a little small for a couple hundred Amps, doesn't it? =-O (IMG:style_emoticons/default/agree.gif) You can get wire with much higher strand count at boating supply stores. It's much more flexible. I went locally to West Marine and bought mine by the foot. The strands in their "marine grade" battery cable are individually plated as well, for corrosion resistance. They also sell heavy duty lugs, shrink sleeving with sealant inside, and an inexpensive lug crimping tool. You put the lug in it, put the cable in the lug, and whack it with a hammer. Shrink the sleeving over it, and you're done. |
ericread |
Mar 4 2008, 03:44 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Keep in mind that electrons travel on the outside of a wire. Therefore, the more strands, the larger the surface area, and the better for the cable to carry current.
Stranded cable rocks! (IMG:style_emoticons/default/aktion035.gif) |
PRS914-6 |
Mar 4 2008, 10:40 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I don't know the size, but in the past I have bought welding cable from a welding supply to make my own battery cables. worked good. The better the cable the better the engine will spin over. (IMG:style_emoticons/default/biggrin.gif) Thats exactly how I wired my car. Welding cable is great and very pliable. I borrowed a hydraulic crimper to put the ends on. I slid some heat shrink on before crimping. They look factory made but are much better |
Joe Ricard |
Mar 5 2008, 06:06 AM
Boat store get the marine stuff I used 4ga. and soldered copper eyes on the ends with heat shrink covers.
jk76.914 |
Mar 5 2008, 07:14 AM
I'm using AWG 2. Not sure I'd be able to solder- lots of mass to heat up. Here's a pic. The terminal is also marine. Easy to disconnect.
Spoke |
Mar 5 2008, 07:33 AM
spunone |
Mar 5 2008, 08:55 AM
Ok Went with the # 2 welding wire crimped and soldered the ends and heat shink should work great . Thanks All (IMG:style_emoticons/default/beer.gif)
zonedoubt |
Jul 16 2008, 03:12 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Lo-Fi Version | Time is now: 9th June 2024 - 07:06 PM |
