What is this piece on the oil cap?, pic... |
pete914 |
Mar 3 2008, 09:46 AM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
What's the piece on the oil filler cap and what is its purpose?
(IMG:http://i15.ebayimg.com/03/i/000/de/24/5f47_1.JPG) |
BarberDave |
Mar 3 2008, 10:42 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Picture insn,t that clear. But if you are talking about the round filter at right angle to the cap. It,s a after market filter that is trying to filter grank case pressure and fumes. Not very well!!!! I had one like it ,it blew oil mist all over the top of the engine. If you are looking to vent and filter the crankcase go to a VW shop and get a remote one there. Vent from PCV valve into remote ,vent it into top of air cleaner. Oh yes don,t forget to remove the guts from the PCV. Dave (IMG:style_emoticons/default/slap.gif) |
ClayPerrine |
Mar 3 2008, 11:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
FYI... Dave, that won't work on this engine. This is a 1.8, and it doesn't have a PCV valve.
pete914 |
Mar 3 2008, 01:03 PM
FYI... Dave, that won't work on this engine. This is a 1.8, and it doesn't have a PCV valve. Okay, right now I have a tube running from the oil filler to the air cleaner on my single carb setup. should I do the same thing with duals (about to switch)? just have the blowoff go to one or both carbs? thanks guys... |
Brando |
Mar 3 2008, 01:51 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
If you're going to have a stock heat setup, its not a good idea to vent into the engine bay like the picture shown. All them bad oil vapors you're trying to avoid just get sucked through the engine and pumped into the cab. I'd run it to a real vent tank or rebreather tank and run the air vent for that out of the engine bay, preferably under.
What's the piece on the oil filler cap and what is its purpose? (IMG:http://i15.ebayimg.com/03/i/000/de/24/5f47_1.JPG) |
ClayPerrine |
Mar 3 2008, 02:51 PM
FYI... Dave, that won't work on this engine. This is a 1.8, and it doesn't have a PCV valve. Okay, right now I have a tube running from the oil filler to the air cleaner on my single carb setup. should I do the same thing with duals (about to switch)? just have the blowoff go to one or both carbs? thanks guys... That depends on the filler cap. The 1.8L has a different oil filler assembly because of the L-jet injection. This is a 1.8L filler cap, so it has a very large hole on it to hook to the air intake tube. It also doesn't have a PCV valve or head breather tubes. If you have a 1.7 or 2.0, you have a different filler cap assembly, and Dave's directions are spot on. |
pete914 |
Mar 3 2008, 04:57 PM
this is what I ordered. How do you suggest I hook it up? one tube coming from the oil filler cap into this box and then vent out the engine tin? seems a little funky...
The guy at CB performance suggested running tubes from the valve covers and then into the air cleaners (drill a hole). Suggestions? (IMG:http://www.cbperformance.com/catalogimages/1754.jpg) |
ClayPerrine |
Mar 3 2008, 10:42 PM
this is what I ordered. How do you suggest I hook it up? one tube coming from the oil filler cap into this box and then vent out the engine tin? seems a little funky... The guy at CB performance suggested running tubes from the valve covers and then into the air cleaners (drill a hole). Suggestions? (IMG:http://www.cbperformance.com/catalogimages/1754.jpg) Find a filler neck with the PCV valve. It will replace the one for the L-Jet. Hook it to the breather box,and use the two tubes provided in the valve covers. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:21 PM |
