AAR - need alittle clarification on how to test, 2.0 |
tod914 |
Mar 10 2008, 12:44 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Hey guys, been through a bunch of threads on the AAR. It wasn't clear to me how to test it when it's off the car. There was mention of hooking up a 12v sorce to it so it heats up and closes. How exactly do I do that? Do I hook up a + line off my car battery to the wire off the AAR? Does it need to be grounded when I do that?
Thanks, Tod |
TheCabinetmaker |
Mar 10 2008, 12:50 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yes and yes
Rand |
Mar 10 2008, 12:54 PM
I gave mine the float test. It sunk. (IMG:style_emoticons/default/laugh.gif)
tod914 |
Mar 10 2008, 12:59 PM
thanks Curt. lol Rand. So If i drive my car in a lake and it has a good aar it should float? Was always wondering how they did that with beatles.
Rand |
Mar 10 2008, 01:50 PM
(IMG:http://www.irememberjfk.com/mt/graphics/floatingbeetle.jpg) No, just the AAR. (IMG:style_emoticons/default/tongue.gif) Mine is without, and I like it that way. If yours is sticky, maybe squirt some good penetrating lube through it and test again. |
p914 |
Mar 10 2008, 04:51 PM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
I have 2 045s available if you decide you want one.
Hammy |
Mar 10 2008, 08:55 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
Where do you put the ground? AAR case?
roadster fan |
Mar 10 2008, 11:38 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Yep case.
I just took two faulty ones apart and fixed em two weekends ago. If you cant get it working send me a pm and I will post he procedure I used. Jim |
JeffBowlsby |
Mar 11 2008, 12:10 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its just a simple heater circuit. Red wire to +12V, case to ground. Shaft rotates on bi-metallic spring to open/close airway with heat.
Attached image(s) |
tod914 |
Mar 11 2008, 12:16 AM
So when I hook it up to the car battery and ground it, how long should it take before it closes?
Thanks for the replies. I seen the rebuilt article by Mr Anders. Was rather interesting. The one I have now, is a rebuild from AA. I can see where the lip was cut off then epoxied upon repair. I have the original that went bad do the wire shorting, think I'll try the repair on that being it's toast any way. |
JeffBowlsby |
Mar 11 2008, 12:37 AM
A few minutes. Engine heat alone is enough to close it even without power.
tod914 |
Mar 11 2008, 12:50 AM
Jeff Im still trying to locate that 75 engine sticker for you. Haven't forgot about it. If I locate it, I'll be sure to send u a digi photo.
Lo-Fi Version | Time is now: 8th June 2024 - 04:24 AM |
