Might have been asked before..... |
quadracerx |
Mar 16 2008, 04:34 PM
Member Group: Members Posts: 426 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Is there a difference in the cases between a 1.7 and a 2.0 bare case? If so..can the 1.7 be modified...
Also...I have a 2.0 I think I can make run....but it is missing two injectors...can I just use the 1.7 injectors to make it fire up...not gonna drive it...just dont want to ruin the brain or anything else.... Thanks... Quad |
SirAndy |
Mar 16 2008, 07:52 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is there a difference in the cases between a 1.7 and a 2.0 bare case? If so..can the 1.7 be modified... yes and yes ... (IMG:style_emoticons/default/smile.gif) the 1.7 case is actually the better of the two and only needs minor modifications to be used with the 2.0L jugs ... (IMG:style_emoticons/default/bye1.gif) Andy |
Dave_Darling |
Mar 16 2008, 09:11 PM
Or no modifications at all? Last I heard, the only real differences were the serial number, and the fact that many early 1.7s didn't have the boss for the windage tray...
The 2.0 crank, rods, pistons, and cylinders will drop right into a 1.7 case. --DD |
Gint |
Mar 16 2008, 09:17 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Really? I sure would like to get a definitive answer on this. DOes soemone out there really now for sure?
SirAndy |
Mar 16 2008, 09:32 PM
The 2.0 crank, rods, pistons, and cylinders will drop right into a 1.7 case. i thought the 1.7L case had to be machined slightly to accept the 2.0L jugs ... (IMG:style_emoticons/default/idea.gif) Andy |
quadracerx |
Mar 16 2008, 11:23 PM
Yikes.... (IMG:style_emoticons/default/confused24.gif) Now Im really confused....LOL Actually thats normal for me....but it would be cool to get the difinitive....(Spelling?) answer...Maybe Jake would know?
What about the injector issue...can I use the 1.7 ones...just to fire the 2.0 off...without hurting the injection brain? Quad |
RoadGlue |
Mar 16 2008, 11:38 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
I just built a 2.0 off a 1.7 case and I had clearance issues just as Andy described. You have to do a little machining to let the piston skirts clear when they're at the bottom of their strokes. If I recall correctly, it was just the most fore and after pistons that wouldn't clear. It's been a year, so it's fuzzy in my mind now. (IMG:style_emoticons/default/smile.gif)
I don't think you'd hurt the ECU or injectors by using 1.7 injectors with a 2.0 system. However, I'd be worried about your running the motor lean, which could cause some real damage? Why half ass it? Just do it right from the start. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:43 PM |
