Help: Ignition problem with 914-6 in Sunnyvale, Will not start. |
bfrymire |
Mar 16 2008, 07:49 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Hello,
I am stuck. I have a 914-6 that will not start. It was running and started running poorly, and I replaced/upgraded several components. I am now using: Brand new: Pertronix coil (3 ohm), Ignitor module (still have the old one.), and a Second Stike digitial control unit. No spark at all. I have wired out the second strike, hot wired the car directly from the battery to the coil, and strapped the - side to engine ground to be sure it wasn't getting the correct power. (I wired it the regular way, through the harness, I did the above to troubleshoot.) Any ideas? I have missed two Autocrosses now! (IMG:style_emoticons/default/wink.gif) I have checked eveything else also, such as gas to the carbs, and fuel pressure. (Not related to no spark, but just being sure.) Help! -- brett |
911quest |
Mar 16 2008, 08:14 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
When you say no spark where are you checking it at the coil wire or the spark plug? If at the plug don't rule out the coil wire or the cap.
bfrymire |
Mar 16 2008, 08:24 PM
When you say no spark where are you checking it at the coil wire or the spark plug? If at the plug don't rule out the coil wire or the cap. Thanks for the prompt reply. I should have also added" new plugs, new rotor and new cap. Old plug wires, but they look in good shape. I checked at the coil. -- brett |
bfrymire |
Mar 21 2008, 08:05 PM
Fixed it. Back on the road again. (IMG:style_emoticons/default/piratenanner.gif)
Turned out, I didn't understand how the pertronix worked. I thought it was acting as a shunt across the coil and collapesed the field through the current loop to ground. Oops. Removed the ground strap to ground, and it runs great now. Doh! Sometimes, you can overthink things... (IMG:style_emoticons/default/headbang.gif) Now, I might be able to make the breakfast and autocrosses coming up! For those, who might be interested. I am using a Ignitor, flamethrower coil, and the Second Strike ignition box. What is had before, was an ancient Jacob's box, and ignitor. I believe the coil was a jacob's also. (1.5 ohms, which is incorrect for the ignitor.) -- brett |
Lo-Fi Version | Time is now: 6th June 2024 - 11:05 AM |
