Zeke |
Never left, but not right.... ![]() ![]() Group: Members Posts: 392 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None ![]() |
You guys are pretty tough, especially when I come up with an idea. But I have been pursuing information on a process of rust protection and arrest for inaccessable areas like the rockers, doors, lower rear portions of the front fenders and rear edge of rear deck lid. Things like that. Not to mention the whole 914!
I know there are fleet applications for the military and the likes of UPS. I have found a few candidates for the job. One is sold under the name Carwell Rust Cop. Another is a cosmoline based product that hardens and seals. Has a fantastic life span as opposed to the Rust Cop which must be renewed periodically. (And that makes marketing sense beacuse Carwell is really in the application business so why would they feature a one time process when they can come back time and again?) A third is a lanolin base that can be used safely around the interior and taillight housings where it might get on the paint. The cosmoline formula is tough to remove once on. There is even another 'Vaseline,' or petolatum, based one for a lighter more temporary use in the shop. Comments? Anyone have any additional info for this type of thing? Seems like with our older cars, we would need as much rust protection as we can get. __________________ |
Zeke |
Stopping rust once it's there is dicey w/o total erradication from what I hear here and other places. That's kind of another topic of it's own.
If you're optimistic, you could believe that if you could prevent anymore moisture and any more air to a rust area, that the rust won't progress. It would be my belief that you could retard it significantly, but not arrest it totally. Another way of looking at the situation is are you going to do nothing? Apparently, that's not how the military and UPS approach it. My own rust erradication procedure is to physically remove all that I can in any way I can and treat what's left several times with phosphoric or tannic acid. At this point, many would use POR-15 or equivalent. But, you can't always get the complete job done or the POR-15 on all surfaces as is the case with the rockers and other concealed areas. At this point, one needs to turn to another product. I'm looking for the best of that product. When I first started this, I used Carwell and it has been good. I can use it indescriminately and wipe it up. It's as mucn of a lubricant as anything. I leave alot of tools outside like my floor jack and it stays pretty nice. I don't live in the part of the country where that is just not done. The cosmoline product that I will test here soon is a much more serious product and would seem well suited for inside rockers. Nothing is a substitute for not letting the rockers get funky in the first place. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Along these lines, I'm curious about whole car protection. I'm planning on dipping my resto-car in acid and I'd like to take that opportunity to implement whole-car rust protection.
steve@ottosvenice.com |
Member ![]() ![]() Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 ![]() |
I melt wax in acetone.,then spray it with my hudson sprayer. Steve
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,276 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(markd@mac.com @ Jan 15 2004, 10:14 PM) I'm planning on dipping my resto-car in acid and I'd like to take that opportunity to implement whole-car rust protection. zinc? |
My buddy was redoing a Panterra. A Whole Panterra body shell went in, Half a body shell came out. Steve
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Most of the body shops shoot wax into the frame rails after a repair. I'll try to find out what the name of the product is that they use.
B |
McMark |
QUOTE(SirAndy @ Jan 15 2004, 10:17 PM) QUOTE(markd@mac.com @ Jan 15 2004, 10:14 PM) I'm planning on dipping my resto-car in acid and I'd like to take that opportunity to implement whole-car rust protection. zinc? Yeah, but who does whole car zinc dipping? |
Howard |
Incontin(g)ent Member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None ![]() ![]() ![]() |
ok, this is too cheap and too easy, but I have had great luck with rustoleum rusty metal primer. it somehow pentrates to gook to bare metal and leaves you with a nice surface. rusty
have used it to paint wrought iron fences, and no problems after 5 years. not as good as zinc coating, but far better that what factory put on these rust buckets to begin with. |
RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
When I had to redo all the flooring,inner & outer long,shift tunnel,firewalls,etc.on my 6 some years back.My boss here at work told me to try a product called OSPHO.
It's a green liquid rust converter sold at any commercial paint store.Glidden,Sherwin Williams,etc. It's about 12.00,and comes in a quart bottle. If ya spray it lightly on surface rust,let is dry overnight,it turns the surface rust a dark black,cause it becomes iron oxide. You ever tried welding,and hit a spot w/rust.It pops a hole in the sheetmetal,right.After I used this stuff, I found I could actually weld right over the affected area.No problem. I sprayed the stuff into all the problem areas,let it do its thing,and then top coated the area w/POR-15.Or in my case I used Eastwood's Corroless. Yes,once this stuff dries,you can paint right over top of it. You should try it,you got nothing to lose. Ron |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
gklinger |
doh! ![]() ![]() Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region ![]() |
QUOTE(Brad Roberts @ Jan 15 2004, 11:24 PM) Most of the body shops shoot wax into the frame rails after a repair. I'll try to find out what the name of the product is that they use. B Brad, is this it? Waxoyl seems to be popular with the British rustbucket crowd. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(redshift @ Jan 16 2004, 06:39 AM) Iron oxide? IT BECOMES RUST!? It becomes iron phosphate. actually, iron oxide is a popular corrosion-resistant treatment. iron is a fascinating element that has a number of more-or-less stable states. normal rust is ferrous oxide. if yoiu work at it, you can surface treat steel to produce ferric oxide. ferric oxide binds iron more tightly than ferrous and will permit no further oxidation. the "blueing" used on guns is ferric oxide; they're "pre-rusted" on purpose to keep them from rusting :-) ... back to surface treatments, i spray LPS-3 into open areas of the body shell when there is access. i used to use an aircraft-approved product called "ACF-50" which was like magic, but i haven't been shopping at the aircraft supply store since i moved from SoCal, so i haven't seen any for a long time. it's expensive - but so is rust ... for small parts (anything that can take the heat and fit into an over) i like to use KGI's 'Gun Kote', a thermosetting polymer resin. obviously i don't know for sure if that's what Otto's is using on that pretty brake caliper, but it wouldn't surprise me. good stuff. |
Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
This guy over on the Pelican board sprayed the entire car in Por-15 and some other stuff before painting it. It actually looks awesome and the underside turned out amazing. It looks like if you spray the por-15 on correctly it is smooth enough paint over and still look good.
POR-15 coating before Painting (IMG:http://forums.pelicanparts.com/uploads2/por15-61073797925.jpg) |
Zeke |
QUOTE(gklinger @ Jan 16 2004, 06:57 AM) QUOTE(Brad Roberts @ Jan 15 2004, 11:24 PM) Most of the body shops shoot wax into the frame rails after a repair. I'll try to find out what the name of the product is that they use. B Brad, is this it? Waxoyl seems to be popular with the British rustbucket crowd. That's interesting. I went to the Waxoyl home page yesterday and found that they would not sell to individuals. No link to the Proper MG site. BUT, what I did find was a home brew recipe for Waxoyl: turpentine, beeswax and light machine oil; heated and combined. COME ON!! I don't know wbout you, but I don't want to heat flammable ingredients just to make some furnature polish. If that is good enough for you, get it. It's not cheap, though at $12 for spray can plus shipping. I would reccommed the Carwell before that. I'll get some more info as I can on the more serious stuff that comes in an areosol can with no CFC's powering it. One last thing, if you can paint it with POR-15, that's the hot ticket. Somehow, I had a problem painting the inside of my rear suspension console and inside my rockers. So, to this day, they have been rinsed with phospho, but not sealed. I did squirt some POR-15 in there, but I know I didn't get complete coverage. I need something easy and inexpensive. And not furnature wax. |
rhilgers |
Member ![]() ![]() Group: Members Posts: 75 Joined: 17-July 03 From: Santa Clara CA Member No.: 919 ![]() |
http://www.eastwoodco.com/RustvsPOR.asp
Carefull testing should be done so the paint sticks the way YOU want it. Rust Encapsulator (by itself) does not grab the paint as well as a normal primer. I put some Rust Encapsulator on some ballards next to my house. 4 years and no rust. -Rich Hilgersom (Yup, the whole car, this shot is at the paint shop) Attached image(s) ![]() |
McMark |
Painting the whole car in POR-15 is a great option, but still has the problem of only covering the areas you can see. Those surfaces aren't really a problem, for the most part. If I could dip in POR-15 then we might be on to something.
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Um,
Someplace I've got one of those Brit car magazines that had a big article on rust. They took metal plates, coated 1/2 of them with the rust inhibitor/treatment and scraped a scratch across the rust treatment. Then they put them on a carousel outdoors and sprayed them with salty water once a week FOR A YEAR. Then they wrote the article. The best materials were those cosmoline like honey colored cavity waxes. As I recall, waxoyl didn't come out too bad but the best materials were several Dinotrol formulations. In the UK they sell them in spray bombs or at the rust treatment places. Did a huge search about 3-4 years ago and could only find the stuff sold in Canada. Iffin you find some, Kenny want! (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif) Group buy and i'm in! (IMG:style_emoticons/default/smilie_pokal.gif) Maybe our Canadian friends can export it for us? (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) Ken |
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
Apparently Waxoyl no longer available especially in the post-911 (not the car) era because of flammability issues. Home recipe from a british Mini site:
Here is a recipe for home made "Waxoyl". It's an old fashioned rust treatment / undercoating: 2 1/2 quarts turpentine 12 oz. beeswax / candle wax 1 quart light machine oil With a cheese shredder, cut the wax into the turpentine, stir until the wax has dissolved, (takes a long time; you can use very low heat (a warm room) to aid but be careful) and thin with the machine oil to a brushable / sprayable consistency. Apply liberally. You can use a hand spray bottle to get into closed-off sections if you have a small access hole. Please be sensible when you make this stuff; don't go breathing the fumes or applying heat and burning down your house. If you have any doubts about it, err on the side of caution and just buy a commercially available product. I'm pretty positive John Paterek applied this to my old 76 914 back in the 80's including injecting into the longitudinals and behind the sail vinyl. Those areas have not rusted to this day. When he first applied it, a bit oozed out on hot summer days around the sail vinyl but then stopped. I'm wondering if there's any role for anti-rust treatment if a car has original finish and is not rusted out? A way to avoid undercoating? Paul |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
FePO4 vs FeO or Fe2O3 or...rust
OSPHO or JASCO and POR 15s Metal ready all contain hpospheric acid. teh acid turns teh IRON OXIDE into IRON PHOSPHATE. with 4 oxigens bonded to the iron, it is not looking to bond with any more . both products are sold at paint stores such as Frazee or Sherwin Williams as a metal prep before paint |
Lo-Fi Version | Time is now: 31st July 2025 - 08:54 AM |
