carb adjustment? |
carb adjustment? |
JOE M |
Apr 17 2008, 11:54 AM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I have dual redline webber carbs on my 72` 914. First there is an ir line going to carb but nothing going to the second carb. Should there be a hose going to each carb? What is the best way for adjustment. I did go to the redline web page but it does not really say how to setup both carbs. Do I get one set and than go to the second or should I do them together? I have never done this. If you look at the attached picture you can see a clear hose on the right but nothing on the other carb.
Carlitos Way |
Apr 17 2008, 12:24 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Check this out: Carburetor Clinic
JOE M |
Apr 17 2008, 12:39 PM
Thanks for the link.
rhodyguy |
Apr 18 2008, 07:20 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you should rotate your picture 90* ccw. if the hose in ? is the clear one it appears to be conected to the oil fill tower. this is one of the methods of drawing off the engine vapors. simple, but not the most elegant. purchase the synchometer/flow meter produced by STE for dialing in your carbs. avail from a host of vendors. the carb writeup at www.aircooled.net is a good one also.
k |
rhodyguy |
you should rotate your picture 90* ccw. if the hose in ? is the clear one it appears to be conected to the oil fill tower. this is one of the methods of drawing off the engine vapors. simple, but not the most elegant. there's not much of a need for a seond line to the other carb. purchase the synchometer/flow meter produced by STE for dialing in your carbs. avail from a host of vendors. the carb writeup at www.aircooled.net is a good one also.
k |
Lo-Fi Version | Time is now: 8th June 2024 - 01:36 AM |
