| Elliot Cannon |
Apr 30 2008, 12:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I researched these air conditioners on the internet and found they cost about $700 to buy. I thought I might try to make one myself. How hard could it be rite? I started with a closed loop water circulation system. It is powered by a 12 volt 2 amp pump with a gallon per minute output. I got it at the local RV parts store. Bent some 3/8 inch copper tubing to fit into an old cooler we have in the garage. Connected some 3/8 rubber hose and used a heat exchanger I bought at a flea market for $5. Filled it with water and tried to bleed out as much air as possible.
| Elliot Cannon |
Apr 30 2008, 12:09 AM
It fits into the cooler and the cooler is filled with water and ice.
| Elliot Cannon |
Apr 30 2008, 12:10 AM
I built a plenum and will use this blower to force fresh air into it to be cooled by the heat exchanger. (Not sure if should be called a heat exchanger but you know what I mean right?) Cold exchanger? Anyway.
| Elliot Cannon |
Apr 30 2008, 12:12 AM
I used a Shop Vac hose for ducting and I had a double outlet attachment for the blower. This is about what it will look like. If the damn thing works I will make another one that looks a little better.
| Elliot Cannon |
Apr 30 2008, 12:17 AM
Here's the other side. I will also make a longer handle so it clears the plenum and pump. I hope to have one working for the ride up to the WRC. The blower and the pump will run on the 914 electrical system OK and I tested it and it seems to blow a good amount of volume. I need to test how cold the air is when it exits the plenum. I might try that tomorrow if there isn't too much to do around the house.
| sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Cool (IMG:style_emoticons/default/biggrin.gif) Idea!
| Sleepin |
Apr 30 2008, 12:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Pretty neat idea for alot of applications! I could definetly make a long drive a lot cooler. I wonder how long before the water became heat soaked (water....soaked :bfh: ) and came up to ambient temperature.
Excited to see if it works Elliot! |
| drive-ability |
Apr 30 2008, 12:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
thats nice, I wonder how well it will work? I would freeze a solid block of Ice. You may be able to do that if you can disassemble the top and reassemble it before you use it...
Very nice !!! My wife had knee surgery and had a knee wrap with a similar system. It kept the water very cold for a long time.. |
| Elliot Cannon |
Apr 30 2008, 12:36 AM
I know the concept works. You can google them and see. The problem is will *mine* work? They're also kinda expensive. I'm not sure if the parts I'm using will work very effeciently. I'll try to hook it up and take a drive tomorrow. Be nice if was in the 80s or so to give it a real test. I'll keep you posted.
Cheers, Elliot |
| So.Cal.914 |
Apr 30 2008, 01:04 AM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
"Go Gadgit Teener"!
Can ya see Elliot laying out across the wing: "HOLD IT LEVEL, I CAN FIX THIS..!" [/img]"[/img] Neat idea, and you had all this stuff laying around the garage? Pretty Cool.(IMG:style_emoticons/default/biggrin.gif) |
| GWN7 |
Apr 30 2008, 01:28 AM
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
compact swamp cooler.... nice......add salt to the ice water.....according to Myth Busters it brings down the water/ice temps faster
| Sleepin |
Apr 30 2008, 02:54 AM
Adding salt would do that. I remember making ice cream as a kid, and to get the ice cream cold enough we dumped salt and ice on the outside of the container while we spun it. Makes sense, saltwater freezes at a lower temp. Good idea.
| blitZ |
Apr 30 2008, 06:22 AM
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Pretty slick and should work well. I have seen a similar setup used on a boat with a small cabin for overnight trips during the summer.
| johannes |
Apr 30 2008, 07:05 AM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
fill it with liquid azote (IMG:style_emoticons/default/wink.gif)
| SLITS |
Apr 30 2008, 07:33 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You should have bought Mike Zs' Cool Suit that was for sale at the Swap Meet .... that's the same system it used 'cept the ice water is pumped thru a lattice in the suit.
Now, paint it yellow. |
| Cap'n Krusty |
Apr 30 2008, 09:27 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Is it just me, or is it really scary that "Myth Busters" is cited as scientific authority ..................... Maybe they don't have high school science teachers anymore ........
The Cap'n |
| marks914 |
Apr 30 2008, 09:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I am going to try this with my heat exchanger installed in the fresh air box
Mark (IMG:http://inlinethumb20.webshots.com/4947/2357708820057582025S500x500Q85.jpg) (IMG:http://inlinethumb21.webshots.com/34196/2059648790057582025S500x500Q85.jpg) |
| marks914 |
Apr 30 2008, 09:54 AM
You could probably run a bilge pump in the bottom of the cooler and just pump the ice water.
Mark |
| MoveQik |
Apr 30 2008, 10:10 AM
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,667 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Elliot has been flipping through the Sporty's Pilot Shop pages again and applying their products to our cars. Any chance it would work on a 105 degree day? I've got an ice chest just looking do be cut up.
Very cool! |
| So.Cal.914 |
Apr 30 2008, 10:18 AM
Any air volume is good when over a hundred degrees, Cool air? Even better...
Oh it gets 125+ here and I have no air in the teener. I may try it myself. |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:07 PM |
