Screeeech!, chngn brks ot |
dandh |
May 2 2008, 02:27 AM
73-Project 914 Group: Members Posts: 33 Joined: 13-April 06 From: Las Vegas, NV Member No.: 5,857 Region Association: Southwest Region |
Got most of the stuff I'm going to need for the big brake change this wk end,rotors,seals,calipers pads,hoses,bearings, ? should I change out the m/c too ?
SGB |
May 2 2008, 07:01 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
a 19 mm MC is available which is an improvement over the stock unit.
Eric_Shea |
May 2 2008, 05:12 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Depends... are you using stock calipers up front?
A 19mm will give you a harder pedal but it will take more effort. You mention big and change in the same sentence. If you are going to a larger pistoned caliper up front then you should change to the 19mm E. |
Lo-Fi Version | Time is now: 16th June 2024 - 04:59 PM |
