Rear sway and possible tire rub question |
rtalich |
May 5 2008, 05:30 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
I'm in the process of changing to five lug and am going to use phone dials, 16x7's. I had 205/55-16 tires mounted on the rears and did a fit check. They fit but is tighter on one side, about 3/16" to 1/4" from rubbing the fender. For a daily driver will these be OK to run? Or should I go with the 195's? I have sway bar installed... even so, will the rear sway that much to have the fender rub?
Thanks, Rob |
SirAndy |
May 5 2008, 07:25 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm in the process of changing to five lug and am going to use phone dials, 16x7's. I had 205/55-16 tires mounted on the rears and did a fit check. They fit but is tighter on one side, about 3/16" to 1/4" from rubbing the fender. For a daily driver will these be OK to run? Or should I go with the 195's? I have sway bar installed... even so, will the rear sway that much to have the fender rub? you should be fine ... you might need to "roll" the inner fender lip to prevent rubbing ... (IMG:style_emoticons/default/bye1.gif) Andy |
Eric_Shea |
May 5 2008, 09:08 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Rob... have you simply tried pulling on the fender lip by hand? You'd be amazed. These things never seem to measure up side to side.
Lo-Fi Version | Time is now: 9th June 2024 - 02:57 AM |
