Carb Timing |
Carb Timing |
Oled |
May 10 2008, 03:06 PM
Newbie Group: Members Posts: 44 Joined: 5-February 03 From: San Antonio, TX Member No.: 247 |
I have been using a stock fuel injecton system on my 2.0 for almost 20 years. A guy I know came by the house yesterday to have me help him set his timing. Unfortunately he has twin Webers with a mechanical advance distributor. He had no reference material for settings. What is the timing set point for this engine that has a stock cam and stock pistons?
Cap'n Krusty |
May 10 2008, 04:02 PM
Probably best to use the stock full advance mark and setting procedure. Might add in a couple of degrees, but no more than that. The Cap'n
Carlitos Way |
May 10 2008, 09:24 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
What's the "stock full advance mark and setting procedure"?
Am I the only one who doesn't know it? C:> |
SGB |
May 10 2008, 09:35 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Its the "full advance" point, which should be at, what, 27degrees btdc? I really can't recall what the "static' timing point was with my Bosch 0.50 (I went to a Mallory). Seems like it was prety high- 10 or 11 degrees btdc. That ends up with a pretty high final advance. Thats b/c those bosch dizzies have steep advance (good) but to much advance at high rpms (bad) When you set based on the full advance, that can't happen. I think that is the value in the full advance concept is that you take a more conservative setting - less likeley to overheat.
Lo-Fi Version | Time is now: 11th June 2024 - 10:51 AM |
