Fuel Pressure Regulator, Which way to turn for more pressure? |
krazykonrad |
May 11 2008, 07:56 PM
Senior Member Group: Members Posts: 1,128 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Which way do I turn the screw on the fuel pressure regulator for more pressure. I'm trying to compensate for a weak fuel pump that I'll replace in the next few days.
THanks! (IMG:style_emoticons/default/beerchug.gif) Konrad |
McMark |
May 11 2008, 07:59 PM
In, clockwise, tighter.
Think tighten the screw for tighter pressure (more), loosen the screw for looser pressure (less). |
krazykonrad |
May 11 2008, 08:02 PM
THank you very much!
Konrad |
Dave_Darling |
May 12 2008, 01:01 AM
Turn the direction that makes the needle in your pressure gauge go up! (IMG:style_emoticons/default/wink.gif)
If you're messing with the pressure, you really should have a gauge on it. --DD |
914Sixer |
May 12 2008, 06:53 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Leave it alone until you get a new pump.You really need a guage in line to adjust it though.
davesprinkle |
May 12 2008, 09:41 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
If your pump can't flow adequate fuel at the stock pressure, it won't be able to flow adequate fuel at a higher pressure. Don't eff with the pressure reg. Get a new pump.
Lo-Fi Version | Time is now: 10th June 2024 - 05:23 PM |
