19mm master cylinder question, one wire |
whitey |
May 12 2008, 01:50 AM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
My new 19mm MC has only one wire connection for the break light...which of the two wires from my wiring harness do I connect?
Thanks, Dave |
Dr. Roger |
May 12 2008, 02:32 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
on a '74, it's referred to as F6, the brake warning switch wire.
brown with a yellow stripe. seen here. http://www.pelicanparts.com/914/parts/Elec...lectric_74C.jpg |
914Sixer |
May 12 2008, 06:50 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Both wires. You need to take the switch off your old master cylinder. Cars up to 74 have a ballast connected on the hand brake behind the dash. If you need a new one I have 2 left. I believe they are no longer available. $30 shippped Priority Mail.
jasons |
May 12 2008, 09:07 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I don't think you necessarily have to use the old switch. The BROWN wire is just a ground lead. The 19mm switch grounds through the M/C to the chassis.
At least thats what I see on the 73 electrical schematic. |
Dave_Darling |
May 12 2008, 09:26 AM
Exactly--just plug the brn/yel wire in, and tape the brn wire out of the way.
--DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:33 AM |
